Discuss
Dryer is blowing thermal fuses
 in
Dryer Repair
Here is a link. Look at #8 http://www.applianceaid.com/diagrams.html This is probably close to your unit. Least confusing way I could
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer is blowing thermal fuses
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #11 (permalink)
Old 01-10-2009, 01:47 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Least confusing way I could think of explaining it
TIMED DRY
Circuit Path:Neutral (R), DOOR switch (D/D1), Timer Contacts WB/TM, TIMER MOTOR, L1
So the timer motor gets 120 volts all the time
AUTO DRY
Circuit Path: L2, Motor's centrifugal switch 2M/1M, HEATER, RESISTOR, Timer Contacts OR/TM, TIMER MOTOR, L2
Right side of the heater with the heater on is actually L1, re: timer contacts R and the 2 thermostats are closed. So the timer motor gets no voltage.
Now if one of the thermostats opens the left side of the Heater becomes L2 and current flows through the Auto path. The resistor is there to reduce the 220 volts to 120 volts so that the timer motor gets the correct voltage across it. Therefore your time only advances when the heater is off.
I have no idea what the interior temperatures should be.
Your way of testing the thermostats is valid.
Be very careful that you do not overheat and cause damage to the dryer or worse yet a fire.
Usually all I do is heat up the face with a soldering gun if it opens normally it is OK. Usually the contacts weld together so the cannot open.
Or you could remove them from the machine and heat the face up on a stove element or in the stove.
Note it makes no difference if you are in timed dry or auto.
Hope this helps
__________________
  #12 (permalink)
Old 01-10-2009, 08:29 PM
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
did you check to see that there is nothing foreign in heater housing
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermal fuses blowing Nathan Vereide Dishwasher Repair 0 11-18-2009 01:49 PM
whirlpool dryer going through thermal fuses knightmare Dryer Repair 3 10-24-2009 02:19 AM
Dryer thermal fuse keeps blowing pocketpet3500 Dryer Repair 3 08-19-2009 05:26 PM
Whirlpool Dryer - Eating Thermal Fuses minomine Dryer Repair 5 05-31-2009 05:40 AM
Whirlpool dryer-thermal fuse keeps blowing needs help Dryer Repair 4 04-13-2009 03:48 PM
