Discuss
Dryer Runs and Stops...
 in
Dryer Repair
Dryer runs great and heats up fine... just started stopping halfway through loads... if you open it up and rotate
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Runs and Stops...
  #1 (permalink)
Old 03-27-2011, 06:10 PM
Junior Member
Rosscondsu is on a distinguished road
Question Dryer Runs and Stops...
Brand: Frigidaire   Age: 5 - 10 years
Dryer runs great and heats up fine... just started stopping halfway through loads... if you open it up and rotate the drum you are able to start it up again...
Dryer is a Frididaire Gallery Heavy Duty-XL Capacity 2-way Tumble Action dry... wondering if this could be a belt, motor, or overheating... curious what to do to be able to fix... Is it cost effective to fix problem or get new dryer.
Ads By Google
  #2 (permalink)
Old 03-31-2011, 06:00 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It sounds like the motor is overheating and shutting off. I would open it up and clean everything out, so that air is flowing good. If it has air flow through the door into the filter, clean that out as lint tends to develop there.
If it continues to be a problem, then the motor is probably in the process of failing and I am not one on changing out motors, so I think a new one is the better choice.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer runs ten seconds and then stops bdibuz Dryer Repair 0 03-16-2011 04:16 PM
Dryer runs for a few minutes and stops. george.henne Dryer Repair 6 02-21-2011 04:52 AM
dryer runs for a while then all electric stops. Bill Lewis Dryer Repair 1 02-04-2009 07:04 AM
Dryer runs 5 min. and stops chuckman Dryer Repair 2 08-14-2008 06:14 PM
dryer runs then stops mike_T Dryer Repair 0 09-04-2007 05:41 AM
