Discuss
dryer won't heat
 in
Dryer Repair
Dryer spins up, but, will not heat. I have 110v coming down on red lead, and the return wire appears
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer won't heat
  #1 (permalink)
Old 10-26-2007, 06:35 AM
pmmr pmmr is offline
Junior Member
pmmr is on a distinguished road
Default dryer won't heat
Model Number: RGX5636aw1   Brand: Roper   Age: 5 - 10 years
Dryer spins up, but, will not heat. I have 110v coming down on red lead, and the return wire appears to switch when push to start button is depressed. I have continuity on the flame sensor and I tested the glow ignitor with a cheater cord, it heated up to red and glowing. I measured about 500 ohms across the 2 connector coil and about 1500 across the 3 connector coil. Are these coils bad? Do you know where I can get a electrical schematic? Thanks, Pat
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 02:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Pat
The first thing I would check is the thermal fuse on the back of the dryer behind the cover. It's located on the air duct. Replace it if it's open.
According to the manufacturer recommendation, if the thermal fuse is blown, the cycling thermostat has to be replaced too. It's located next to the thermal fuse.
The thermal fuse
The cycling thermostat
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX5636AW1
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-29-2007, 06:32 AM
Junior Member
Default
Thanks, but, the two wires coming down to the assembly seem to be switching, would that be happening if the thermal was blown? I will check tonight. Also, I found the breakdown drawings earlier, I am looking for an electrical one line drawing, thanks. Pat
  #4 (permalink)
Old 11-02-2007, 02:03 PM
Junior Member
Default
Thermal fuse is ok, now what? Thanks
  #5 (permalink)
Old 11-02-2007, 02:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Pam
I found the wiring diagram for your dryer. The gas dryer diagram is on page 2.
I hope it will help.
__________________
  #6 (permalink)
Old 11-06-2007, 08:55 AM
Junior Member
Default
Thanks for the drawing, that helps greatly. I made a mistake, the fuse was bad, will change both as suggested.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer no Heat KrazyK55 Dryer Repair 6 01-15-2008 02:22 PM
dryer will not heat? radio963 Dryer Repair 1 11-09-2007 10:02 AM
Dryer won't heat Derrick Dryer Repair 4 10-24-2007 05:31 AM
dryer doesn't heat undertaker Dryer Repair 0 10-22-2007 11:54 AM
dryer heat karen Dryer Repair 0 07-23-2007 01:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
