| » Won't Start |
Model Number: DDE5300GBLAD Brand: GE Age: More than 10 years
Dryer won't start. Timer still works. I thought of just relacing the starter switch and see what happens, but don't know if the door switch may be the problem, or something else. Don't want to spend for a service call on an old dryer. Any troubleshooting advice?
Hi vns
You are on the right way. The first thing you have to check are the door switch and the start switch. Keep me updated, please. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
You have to check switches for continuity and you need a meter to do it.
Check the start switch for continuity across two terminals with switch in start position. If it's open, it has to be replaced. The bad news - the part is no longer available. Gene.
__________________
Thanks Gene, story of my life, with the main switch being no longer available. I do believe that switch is OK and has continuity, if the meter is good, and I see you have a door switch available. How is that accessed? It looks small from your photo, with no wires. Does it just pull out (pry) or do I have to take the front of the dryer off? Thanks.
| Display Modes | |
| Microwave won't start up | ksobotik | Microwave Repair | 3 | 10-21-2007 12:41 AM |
| just buzzes won't start | CorrieA | Washer Repair | 3 | 09-21-2007 04:40 AM |
| Dryer will not start | bob38 | Dryer Repair | 2 | 09-19-2007 08:59 PM |
| Wont start/start switch replaced | awilliams197 | Dryer Repair | 1 | 09-18-2007 02:33 AM |
| washer won't start | jimzoe@gmail.com | Washer Repair | 1 | 09-17-2007 03:51 AM |
