i am wanting to replacethe heat element but not sure which one itis or how to remove the old one. it is not made like any of the others i have seen.
If you take off the back (be sure and disconnect the dryer first) you will see the heater housing. Take off the connection at the top and you should be able to disconnect the wiring on the element and the thermal safety devices and remove the housing. You can then take the old element out and replace it.
Good luck.
