Discuss
Maytag dryer not heating.
 in
Dryer Repair
S/N A1455441KH Dryer is not heating at all on any setting even with vent hose open on the back.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag dryer not heating.
  #1 (permalink)
Old 10-25-2007, 09:57 AM
elkski elkski is offline
Junior Member
elkski is on a distinguished road
Default Maytag dryer not heating.
Model Number: LDE9314ACE   Brand: Maytag   Age: 5 - 10 years
S/N A1455441KH
I have taken off the access covers. the main 220 terminal looks ok. I have tried to take off screws thinking the whole 3 sides would come off to provide access.
The parts check says that the heater assy. is AP277083 and might as well get a new belt as I feel some rough spots. P/N AP3988821
I was going to hook up a meter to check to see of the heater terminals are getting power?
In holding pattern now.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-25-2007, 11:17 AM
Junior Member
Default
well it appears this site is slow to respond if you are used to an hour time.. Maybe it takes the evening shift to respond.
anyway I got the front panel off and might have found my main problem. The ground wire from the dry sensor might have been off or came off when I took the door off? I still want to replace the belt... Not sure how I will get it around the drum??
  #3 (permalink)
Old 10-25-2007, 12:21 PM
Junior Member
Default
Not so lucky as the loose sensor wire. must have knoced it off when removing the front the spade was very loose so I thought that was it.
No luck it is a broken heater coil..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag oven not heating moongidget Oven Repair (including Ranges and Cooktops) 1 02-22-2008 09:05 AM
Maytag dryer not heating up on all cycles and not properly drying clothes. radioman464 Dryer Repair 1 10-18-2007 04:48 AM
Dryer not heating VBN Dryer Repair 1 08-20-2007 11:16 AM
Maytag - Dryer not heating timer mode freebird Dryer Repair 0 08-16-2007 12:06 PM
Dryer Not Heating Jorja Dryer Repair 1 08-16-2007 11:14 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
