tbtpounce
#1 Posted : Thursday, March 24, 2011 10:42:14 AM(UTC)
tbtpounce
Good afternoon. I have a Whrilpool Dryer MOD# LER4434AQ0 that is not producing heat. I checked the wiring and fuse and all is good. My question is "How do I get the Heater Box off so I can get to the Heating Element". I got the clip off the top but still can't move it. I appreciate any help you can give.
Tom
tmackowsky@gmail.com
sidfink43
#2 Posted : Saturday, March 26, 2011 4:39:14 PM(UTC)
sidfink43
You access the heater by taking off the rear panel. First check to see that you are getting 120v to each side of the connection block, then disconnect the power and take off the back.
You will see two safety fuses on the heater housing. Check them for continiuity and if they are ok, check the resistence on the heater coil, ought to be 10 to 13 ohms.
If a safety fuse is bad (open) replace both and thorough clean out the lint chute and every place else you find lint.
tbtpounce
#3 Posted : Saturday, March 26, 2011 7:21:02 PM(UTC)
tbtpounce
I did get the heater housing off. The only two items I see on the hosing is the Thermal cut-off and I think the other is the Thermostat. Is this what you mean when you say " two safety fuses" and if so should they both have continiuity? because the bottom one does but the top one is open.
sidfink43
#4 Posted : Sunday, March 27, 2011 5:31:57 AM(UTC)
sidfink43
They are both safety thermal fuses, the thermostat is at another place.
They both should have continuity, so replace both as a set, clean it out and you should be all set.
tbtpounce
#5 Posted : Monday, April 18, 2011 8:52:14 AM(UTC)
tbtpounce
Thank-you. All your advice worked and I am good to go.
sidfink43
#6 Posted : Monday, April 18, 2011 9:11:34 AM(UTC)
sidfink43
Well happy to hear that and thanks for updating us. Good luck with your machine in the future.
Dryer has no heat. (Dryer Repair)
by Goatman48 2/12/2018 3:16:53 PM(UTC)
my roper dryer has no heat (Dryer Repair)
by vanj333 8/8/2012 3:11:18 PM(UTC)
Dryer has NO heat, but runs (Dryer Repair)
by MCH_STL 7/12/2012 3:20:18 PM(UTC)
maytag dryer HAS NO HEAT! (Dryer Repair)
by gtopij 5/1/2012 2:13:30 PM(UTC)
Frigidaire Dryer Has No Heat (Dryer Repair)
by moody9207 4/22/2012 6:18:15 PM(UTC)
electric dryer has no heat (Dryer Repair)
by Anthony Cetani 1/22/2012 5:52:08 AM(UTC)
Dryer has no heat (Dryer Repair)
by marcustheman 10/17/2011 7:22:16 AM(UTC)
by Ken Louie 9/27/2011 3:50:23 PM(UTC)
Frigidare Dryer has no heat and timer does not work (Dryer Repair)
by qt3110 9/19/2011 9:05:10 PM(UTC)
by slowey 6/30/2011 11:47:52 AM(UTC)
dryer has no heat & wont run (Dryer Repair)
by K Graber 4/5/2011 10:34:19 AM(UTC)
Gas Dryer has no heat (Dryer Repair)
by bmpaul 8/11/2010 2:48:42 PM(UTC)
by slim10 4/8/2010 8:10:12 AM(UTC)
HELP!!! Dryer has no heat (Dryer Repair)
by quinn9829 11/12/2009 6:44:51 AM(UTC)
by tlpyle 7/16/2009 6:33:20 PM(UTC)
