Dryer stopped working after power surge No lights on control panel Purchased new encoder & control board Installed encoder no change Installed new board all lights working Turned dryer on & it runs for about 20 seconds the lights on timer blink twice You can push start & it runs 20 seconds & stops again Any suggestions on checking further or could there be a problem with limit switch or new board
Thanks for any help
There is a set of diagnostics built into the control board, but I cannot link you to the tech info as Maytag no longer makes that available. See if there are tech notes under the console or inside the cabinet, and if not see if Maytag can get them to you, which they should since you paid for their machine.
