Discuss
Instructions for changing coils
 in
Dryer Repair
Hello, I'm changing coils in my gas dryer and wondering if there is a diagram for this...which is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Instructions for changing coils
  #1 (permalink)
Old 10-24-2007, 06:09 PM
Leesa Leesa is offline
Junior Member
Leesa is on a distinguished road
Red face Instructions for changing coils
Model Number: LGN2000LWO   Brand: Whirlpool   Age: 1 - 5 years
Hello,
I'm changing coils in my gas dryer and wondering if there is a diagram for this...which is more convenient to access the coils, front or back? Just looking for the fastest way...
thanks
Leesa
Related Models
Whirlpool LGN2000PG0 29"gas Dryer
Whirlpool LGN2000PG1 29"gas Dryer
Whirlpool LGN2000PW0 29"gas Dryer
Whirlpool LGN2000PW1 29"gas Dryer
Whirlpool LGN3434AW0
Whirlpool LGN3624BN0
Whirlpool LGN3624BN1
Whirlpool LGN3624BN2
Whirlpool LGN3624BW0
Whirlpool LGN3624BW1
Whirlpool LGN3624BW2
Whirlpool LGN3634DW0
Whirlpool LGN3634DW1
Whirlpool LGP6646AN0
Whirlpool LGP6646AN1
Whirlpool LGP6646AN2
Whirlpool LGP6646AW0
Whirlpool LGP6646AW1
Whirlpool LGP6646AW2
Whirlpool LGP6848AN0
Whirlpool LGP6848AN1
Whirlpool LGP6848AW0
Whirlpool LGP6848AW1
Whirlpool LGP7858AN0
Whirlpool LGP7858AN2
Whirlpool LGP7858AQ2
Whirlpool LGP7858AW0
Whirlpool LGP7858AW2
Whirlpool LGP7858AZ2
Frigidaire LGQ1442ES0 Frigidaire/dryer
Frigidaire LGQ2152EE0 Frigidaire/dryer
Frigidaire LGQ2152ES0 Frigidaire/dryer
Frigidaire LGQ332DS0 Frigidaire/dryer
Frigidaire LGQ6000ES0 Frigidaire/dryer
Frigidaire LGQ6000ES1 Frigidaire/dryer
Frigidaire LGQ6000ES2 Frigidaire/dryer
Frigidaire LGQ642DS0 Frigidaire/dryer
Frigidaire LGQ7000EG0 Frigidaire/dryer
Frigidaire LGQ7000ES0 Frigidaire/dryer
Frigidaire LGQ7000ES1 Frigidaire/dryer
Frigidaire LGQ7000ES2 Frigidaire/dryer
Whirlpool LGQ7030KQ0
Whirlpool LGQ7030KQ1
Whirlpool LGQ7030KQ2 29"gas Dryer
Whirlpool LGQ8000HQ0
Whirlpool LGQ8000HQ1
Whirlpool LGQ8000JQ1
Whirlpool LGQ8000JQ2
Whirlpool LGQ8000JQ3
Whirlpool LGQ8000JQ4 29"gas Dryer
Whirlpool LGQ8000JQ5 29"gas Dryer
Whirlpool LGQ8100KQ0
Whirlpool LGQ8100KQ1
Whirlpool LGQ8100KT0
Whirlpool LGQ8100KT1
Whirlpool LGQ8611LG0
Whirlpool LGQ8611LG1 27"gas Dryer
Whirlpool LGQ8611LW0
Whirlpool LGQ8611LW1 27"gas Dryer
Whirlpool LGQ8611PG0 27"gas Dryer
Whirlpool LGQ8611PG1 27"gas Dryer
Whirlpool LGQ8611PG2 27"gas Dryer
Whirlpool LGQ8611PG3 27"gas Dryer
Whirlpool LGQ8611PW0 27"gas Dryer
Whirlpool LGQ8611PW1 27"gas Dryer
Whirlpool LGQ8611PW2 27"gas Dryer
Whirlpool LGQ8611PW3 27"gas Dryer
Whirlpool LGQ8621PG0 27" Gas Dryer
Whirlpool LGQ8621PG1 27" Gas Dryer
Whirlpool LGQ8621PG2 27" Gas Dryer
Whirlpool LGQ8621PG3 27" Gas Dryer
Whirlpool LGQ8621PW0 27" Gas Dryer
Whirlpool LGQ8621PW1 27" Gas Dryer
Whirlpool LGQ8621PW2 27" Gas Dryer
Whirlpool LGQ8621PW3 27" Gas Dryer
Whirlpool LGQ8800JQ0
Whirlpool LGQ8800JQ1
Whirlpool LGQ8800JQ2
Whirlpool LGQ8800JT0
Whirlpool LGQ8800JT1
Whirlpool LGQ8800JT2
Whirlpool LGQ8857HQ0
Whirlpool LGQ8857HQ1
Whirlpool LGQ8857HZ0
Whirlpool LGQ8857HZ1
Whirlpool LGQ8857JQ0
Whirlpool LGQ8857JQ1
Whirlpool LGQ8857JQ2
Whirlpool LGQ8857JQ3
Whirlpool LGQ8857JT0
Whirlpool LGQ8857JT1
Whirlpool LGQ8857JT2
Whirlpool LGQ8857JT3
Whirlpool LGQ8858HQ0
Whirlpool LGQ8858HQ1
Whirlpool LGQ8858HZ0
Whirlpool LGQ8858HZ1
Whirlpool LGQ8858JQ0
Whirlpool LGQ8858JQ2
Whirlpool LGQ8858JQ3
Whirlpool LGQ8858JT0
Whirlpool LGQ8858JT2
Whirlpool LGQ8858JT3
Whirlpool LGQ8858JZ0
Whirlpool LGQ8858JZ2
Whirlpool LGQ9030PQ0 29"gas Dryer
Whirlpool LGQ9030PQ1 29"gas Dryer
Whirlpool LGQ9508KQ0
Whirlpool LGQ9508KQ1
Whirlpool LGQ9508LG0
Whirlpool LGQ9508LW0
Whirlpool LGQ9508LW1 29"gas Dryer
Whirlpool LGQ9508PG0 29"gas Dryer
Whirlpool LGQ9508PG1 29"gas Dryer
Whirlpool LGQ9508PW0 29"gas Dryer
Whirlpool LGQ9508PW1 29"gas Dryer
Whirlpool LGQ9557KQ0
Whirlpool LGQ9557KQ1
Whirlpool LGQ9557KT0
Whirlpool LGQ9557KT1
  #2 (permalink)
Old 10-24-2007, 06:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Leesa
To get access to all the parts inside the dryer, remove two screws at the lint screen slot and using a putty knife, push and pry the clip on each side in front of the top panel to release the holding clips. Lift up the top panel until it rests on the hinges. Unplug the quick disconnect plug for the door switch. Remove a screw from each side of the front panel. Pull the front panel up and toward yourself to release it from the retainer clips. Looking under the drum you'll find the idler pulley with the belt. Draw a picture of the belt that goes through the idler pulley onto the motor pulley so you will know how to assemble it back. Remove the belt and pull out the drum. Now you have access to all parts inside the dryer.
Good luck.
__________________
  #3 (permalink)
Old 10-25-2007, 08:16 AM
Junior Member
Smile project done!
Gene,
Thank you for the excellent instructions, especially the one to diagram the belt before I took it off! It didn't take long and I had the coils changed. (My children were very impressed) You were a life saver!!
Thanks again,
Leesa
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help - instructions to install oven igniter lrg51 Oven Repair (including Ranges and Cooktops) 45 09-21-2009 11:25 PM
Need Wiring instructions PLEASE!!! Scott e Dryer Repair 2 10-24-2007 02:06 PM
Control Board Installation Instructions tbj66 Refrigerator & Freezer Repair 3 09-11-2007 11:53 PM
changing thermostat ratboy915 Oven Repair (including Ranges and Cooktops) 3 07-27-2007 09:47 AM
Changing Pump pdiddy Washer Repair 1 07-20-2007 07:05 PM
