Discuss
Amana Electric Dryer- No Heat
 in
Dryer Repair
I am trying to repair this electric dryer with no heat,I have checked the power supply (240v) , the heating
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Electric Dryer- No Heat
  #1 (permalink)
Old 10-24-2007, 04:01 PM
didier didier is offline
Junior Member
didier is on a distinguished road
Default Amana Electric Dryer- No Heat
Model Number: LE3502L   Brand: Amana   Age: More than 10 years
I am trying to repair this electric dryer with no heat,I have checked the power supply (240v) , the heating element, thermostat, over heat fuse link, centrifical switch at the motor, and I can't find the problem.I did replace the timer assemble with no new results.The motor will run and the blower is operational as well. I can't seem to figuire this one out, I hooked up the heating element assembly with its safetys direct to 240v and it operates.The model is a Amana electric cloths dryer #LE3502L, S/n 9206006443.I am open to any input. Thank You
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 08:25 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
check for any vurnt wires from the terminal block to the heater
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana dryer top removal gremlin Dryer Repair 2 08-05-2008 06:47 PM
Dryer help no heat.Whirlpool 8cycle electric apathy23 Dryer Repair 1 10-24-2007 05:08 AM
electric dryer has no heat, but still runs in both permanent press and timed dry. chrisnross Dryer Repair 1 09-12-2007 06:51 AM
maytag Electric dryer gws001 Dryer Repair 17 08-14-2007 06:58 PM
Electric Dryer too hot jim k Dryer Repair 3 07-25-2007 05:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
