Need help? Dryer runs but without any heat. It only blows cold air.
Hello, You would need a volt meter to make some test. The most common issue on this particular unit is the igniter. You would need to remove the lower access panel and test the igniter with your volt meter. You can make a voltage check 110v should be present or you can take a continuity test. I know this unit well and can answer any more repair related questions you have. Appliance & Refrigerator RepairLet me know
