Discuss
Dead Roper, no heat
 in
Dryer Repair
I have a Roper REL4434AWD Electric dryer with no heat. I checked for voltage at the heater and I have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dead Roper, no heat
  #1 (permalink)
Old 03-21-2011, 03:00 PM
Junior Member
Bmettie is on a distinguished road
Default Dead Roper, no heat
Model Number: REL4434AWD   Brand: Roper   Age: 5 - 10 years
I checked for voltage at the heater and I have nothing.
I have continuity across the lower cycling thermostat but not the upper. Does that mean that it is bad?
I have continuity across the thermal fuse.
I have continuity across the top and bottom of the thermostat int he exhaust but nothing across the 2 purple wires. I've read that its an internal heater and should read ~30K, true? Could it be bad? Any help or a schematic would be beautiful? I cant find anything online.
Thanks in advance
Ads By Google
Related Models
Whirlpool REL4622BL0
Whirlpool REL4622BL1
Whirlpool REL4622BL2
Whirlpool REL4622BQ0
Whirlpool REL4622BW0
Whirlpool REL4622BW1
Whirlpool REL4622BW2
Whirlpool REL4622DL0
Whirlpool REL4622DL1
Whirlpool REL4622DW0
Whirlpool REL4622DW1
Whirlpool REL4632BL0
Whirlpool REL4632BL1
Whirlpool REL4632BL2
Whirlpool REL4632BL3
Whirlpool REL4632BQ0
Whirlpool REL4632BQ1
Whirlpool REL4632BQ2
Whirlpool REL4632BQ3
Whirlpool REL4632BW0
Whirlpool REL4632BW1
Whirlpool REL4632BW2
Whirlpool REL4632BW3
Whirlpool REL4632DL0
Whirlpool REL4632DL1
Whirlpool REL4632DW0
Whirlpool REL4632DW1
Whirlpool REL4634BL0
Whirlpool REL4634BL1
Whirlpool REL4634BL2
Whirlpool REL4634BL3
Whirlpool REL4634BW0
Whirlpool REL4634BW1
Whirlpool REL4634BW2
Whirlpool REL4634BW3
Whirlpool REL4636BL0
Whirlpool REL4636BL1
Whirlpool REL4636BL2
Whirlpool REL4636BL3
Whirlpool REL4636BW0
Whirlpool REL4636BW1
Whirlpool REL4636BW2
Whirlpool REL4636BW3
Whirlpool REL5646AL0
Whirlpool REL5646AW0
General Electric REM10E01 Counter top microwave
General Electric REM10F01 Counter top microwave
General Electric REM10F02 Counter top microwave
General Electric REM10F03 Counter top microwave
General Electric REM10G01 Counter top microwave
General Electric REM25SJ01 Counter top microwave
General Electric REM25SJ02 Counter top microwave
General Electric REM25SJ03 Counter top microwave
General Electric REM29H01 Counter top microwave
General Electric REM29H02 Counter top microwave
General Electric REM2F01 Counter top microwave
General Electric REM2F02 Counter top microwave
General Electric REM2G01 Counter top microwave
General Electric REM30E01 Counter top microwave
General Electric REM30F01 Counter top microwave
General Electric REM30F02 Counter top microwave
General Electric REM30F03 Counter top microwave
General Electric REM30G01 Counter top microwave
General Electric REM4F01 Counter top microwave
General Electric REM4F02 Counter top microwave
General Electric REM4F03 Counter top microwave
General Electric REM4G01 Counter top microwave
General Electric REM4H01 Counter top microwave
Frigidaire REM638BDL0 Frg(v1) / Electric Range
Frigidaire REM638BDL1 Frg(v2) / Electric Range
Frigidaire REM638BDL2 Frg(v3) / Electric Range
Frigidaire REM638BDL3 Frg(v4) / Electric Range
Frigidaire REM638BDL4 Frg(v2) / Electric Range
Frigidaire REM638BDL5 Frg(v1) / Electric Range
Frigidaire REM638BDL6 Frg(v2) / Electric Range
Frigidaire REM638BDW0 Frg(v5) / Electric Range
Frigidaire REM638BDW1 Frg(v6) / Electric Range
Frigidaire REM638BDW2 Frg(v7) / Electric Range
Frigidaire REM638BDW3 Frg(v8) / Electric Range
Frigidaire REM638BDW4 Frg(v1) / Electric Range
Frigidaire REM638BDW5 Frg(v3) / Electric Range
Frigidaire REM638BDW6 Frg(v4) / Electric Range
Frigidaire REM638MH7 Frg(v1) / Twin 30 " Range
Frigidaire REM638MH8 Frg(v1) / Twin 30 " Range
Frigidaire REM638ML7 Frg(v2) / Twin 30 " Range
Frigidaire REM638ML8 Frg(v2) / Twin 30 " Range
Frigidaire REM638MM7 Frg(v3) / Twin 30 " Range
Frigidaire REM638MM8 Frg(v3) / Twin 30 " Range
Frigidaire REM638MW7 Frg(v4) / Twin 30 " Range
Frigidaire REM638MW8 Frg(v4) / Twin 30 " Range
Whirlpool REM7000
Whirlpool REM70001
Whirlpool REM7200
Whirlpool REM72001
Whirlpool REM72002
Whirlpool REM7400
Whirlpool REM74001
Whirlpool REM74002
Whirlpool REM7600
Whirlpool REM76001
Frigidaire REM77BCB1 Frg(v0) / Electric Wall Oven
Frigidaire REM77BCB2 Frg(v1) / Electric Wall Oven
Frigidaire REM77BCB3 Frg(v2) / Electric Wall Oven
Frigidaire REM77BCB4 Frg(v3) / Electric Wall Oven
Frigidaire REM77BDB0 Frg(v1) / Wall Oven
Frigidaire REM77BDB1 Frg(v2) / Wall Oven
Frigidaire REM77BDB2 Frg(v3) / Wall Oven
Frigidaire REM77BDB3 Frg(v4) / Wall Oven
Frigidaire REM77BL2 Frg(v1) / Wall Oven and Microwave
Frigidaire REM77BL4 Frg(v2) / Wall Oven and Microwave
Frigidaire REM77BLB0 Frg(v1) / Electric Wall Oven & Microwave
Frigidaire REM77BLB1 Frg(v2) / Electric Wall Oven & Microwave
Frigidaire REP302CD1 Kel(v1) / 30 " Electric Range
Frigidaire REP302CD2 Kel(v2) / Electric Range
Frigidaire REP302CF1 Kel(v2) / 30 " Electric Range
Frigidaire REP302CF2 Kel(v3) / Electric Range
Frigidaire REP302CJ2 Kel(v5) / Electric Range
Frigidaire REP302CT1 Kel(v3) / 30 " Electric Range
Frigidaire REP302CV1 Kel(v4) / 30 " Electric Range
Frigidaire REP302CV2 Kel(v4) / Electric Range
  #2 (permalink)
Old 03-24-2011, 05:58 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I would change out both of these thermostats, that's recommended which is why they come in a kit and you should be back in business.
Part number: AP3094224
Your lack of continuity accross one of them is one reason why you do not get heat.
Also, thorough clean out the dryer and the exhaust chute. I also recommend changing out the cycling thermostat when I do these types of repairs just so everything that controls heat is new.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Roper Gas Dryer won't heat mamabear001 Dryer Repair 0 09-26-2009 06:06 PM
Roper Gas Dryer, No Heat, All else ok teemade Dryer Repair 0 09-22-2009 06:20 PM
Is my Roper dead? Gottatts2 Dryer Repair 6 12-12-2008 03:45 PM
roper dryer with no heat aaronii Dryer Repair 2 04-18-2008 06:33 AM
