| » Gas Valve Solenoid Coil |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 110.76822695 Brand: Kenmore Age: 5 - 10 years
How do I know if the Gas Valve Solenoid Coils are bad and are the cause to my dryer not heating. I tested continuity on Ignitor, Fuse, Thermstat, thermocoil, and heat sensor. All show continuity.
Woud i get a continutiy reading if I was to test from one coil to another? I currently do not get a reading and believe this is where my problem is. |
Hi Teewaddy
What parts did you call "thermocoil" and "heat sensor"? The power to the igniter comes through: The thermal fuse The cycling thermostat The hi limit thermostat The flame sensor The holding and the secondary gas valve coils All of these parts should be normally closed. The holding and booster coil (the one with the three terminals) should be checked across outer terminals. Good luck. Gene.
__________________
Professional appliance repair services in Orange County, California. Last edited by Gene : 10-25-2007 at 04:39 PM. |
Per your question below.
"What parts did you call "thermocoil" and "heat sensor"? I checked all of the below that you listed below. All tested normally closed or as I call it "received a beep" from my ohm meter testing for continuity. Is this true? The Thermal Fuse, The cycling thermostat, The hi limit thermostat, and the flame sensor all beeped/showed continuity. If I could clarify your next statement "The holding and booster coil (the one with the three terminals) should be checked across outer terminals." Do you mean that I shoud have continuity from the 3 tab coil over to the 2 tab coil? Because I dont receive a beep from my ohm meter when I check any combination from the three to the two tab coil. Thanks for clarifying for me. |
Both coils should be checked separate, one at a time. The one with the three terminals should be checked across outer terminals.
__________________
Professional appliance repair services in Orange County, California. |
Gene, how many ohms is too many across the coils, I get about 500 to 1500 ohms with my fluke digital meter?
Hi pmmr
What is wrong with your dryer? What is the complete model number? Please post it as a new thread. Gene.
__________________
| Display Modes | |
| Drain Solenoid Keeps Melting | valky | Dishwasher Repair | 2 | 08-16-2007 07:39 AM |
| Side by Side freezer coil iceing over | bksbjmds8 | Refrigerator & Freezer Repair | 2 | 07-25-2007 12:27 PM |
| whirlpool electric coil cooktop | jaffej | Oven Repair (including Ranges and Cooktops) | 0 | 07-25-2007 09:06 AM |
| replace burner solenoid | richard | Oven Repair (including Ranges and Cooktops) | 2 | 07-21-2007 10:56 AM |
| freezer coil freezing | trey1122 | Refrigerator & Freezer Repair | 1 | 07-20-2007 05:27 PM |
