Discuss
Dryer Not Functioning
 in
Dryer Repair
My Admiral LNC7764A71 was not working. I verified the power to the unit and verified the Thermal Fuse did not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Not Functioning
  #1 (permalink)
Old 03-20-2011, 10:01 AM
Junior Member
mjs204 is on a distinguished road
Default Dryer Not Functioning
Brand: Admiral   Age: 5 - 10 years
My Admiral LNC7764A71 was not working. I verified the power to the unit and verified the Thermal Fuse did not have continuity. I replaced both the Thermal Fuse and and High Limit and confirmed their continuity. The using still is not functioning and the interior light is not working. What is the next step to diagnose the problem?
Ads By Google
  #2 (permalink)
Old 03-21-2011, 02:42 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram
Replacement parts for ADMIRAL LNC7764A71 DRYER- ELE | AppliancePartsPros.com
Next I would check the power and then the door switch.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer blower not functioning hlt427 Dryer Repair 5 04-07-2010 04:41 PM
Gas oven not functioning AlanS Oven Repair (including Ranges and Cooktops) 13 01-08-2010 04:56 AM
Screen controls not functioning properly on Harmony Electric Dryer MomWithBrokenHarmony Dryer Repair 1 10-24-2009 09:20 AM
GE Dishwasher not functioning managemyhome Dishwasher Repair 4 10-03-2009 03:27 PM
dryer not functioning fisherman Dryer Repair 0 01-05-2008 09:32 AM
