richcrk
#1 Posted : Friday, January 2, 2009 8:50:34 AM(UTC)
richcrk
Wondering if this is a timer problem. Set timer to 20 min. timed and it works fine but any other timed setting it does nothing. Applied a little pressure and it worked on 60 min. timed. Also in auto it works on cool down always; other settings just sometimes.
#2 Posted : Saturday, January 3, 2009 6:31:17 AM(UTC)
Here is your parts breakdown
Model LER7646AN0
And a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203401723.pdf
From your description of timed dry, it does sound like a timer problem, probably the gearing inside the timer is messed up.
