Discuss
Dryer won't heat,replaced parts
 in
Dryer Repair
The electric dryer starts/runs fine...but will only blow cold air. I have instaled new...thermal fuse (was blown), dryer cycling thermostat,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat,replaced parts
  #1 (permalink)
Old 03-19-2011, 09:57 AM
Junior Member
Bradx is on a distinguished road
Default Dryer won't heat,replaced parts
Model Number: LER4634EQO   Brand: Whirlpool   Age: 5 - 10 years
heating element with new thermal cut-off, and high-limit thermostat.
I have checked for 240v at the box and terminal block...both good.
While running in Perm.press high heat cycle, using a circut tester on the
timer I get 240v between Red and Blue, 120 between Red and Purple,
120 between Red and Orange, 120 between Red and White. Also checked
between Orange and Orange for resistor next to start switch, 120 also.
What's left to check or replace?
Bradx
Related Models
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
  #2 (permalink)
Old 03-19-2011, 03:58 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
[url="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246509"]http://www.appliancepartspros.com/partsearch/model.aspx?mod
See the attachment for the wiring diagram.
Unplug the unit, set it mid-scale timed dry and check timer switch 2, it should be 0 ohms.
You could also attach one meter lead to Black (L1), leave it here and then work your way back through the heater circuit component by component using ohms.
If everything checks out OK to the far side of the heating coil (right side on the wiring diagram) then odds are either the centrifugal switch is not closing for some reason or the red is burned out somewhere.
__________________
  #3 (permalink)
Old 03-19-2011, 04:48 PM
Junior Member
Default testing
Quote:
Originally Posted by denman View Post
Thanks for thr reply,
I only have a circut tester...Could I take the timer to the
local parts shop to be tested?
Is the centrifugal switch on the motor? And can I test it
without taking the motor out?
Brad
  #4 (permalink)
Old 03-19-2011, 06:21 PM
Senior Expert
APP Volunteer
Default
Since you have started repairing your appliances I would recommend you buy yourself a meter. If you had one earlier you would have been able to check the parts with it before replacing them. It will let you read AC volts (it is nice to know what the actual voltage is), DC volts (comes in handy checking batteries etc.) and resistance (ohms). If possible I always try to check parts using ohms why fool around with a live unit and risk a shock or an arc/spark if you do not have to.
Could I take the timer to the local parts shop to be tested?
They may do it for you problem is you have to know where it is set.
So if they rotate the shaft it is messed up.
Yes. There are two of them. A mechanism in the motor closes them when the motor gets close to operating speed.
One connects in the heating coil, it ensures that the coil does not come on until there is air flow.
The other disconnects the start winding in the motor as leaving it in circuit would overheat the motor. It's normally open side is wired in para;llel with the start switch and it closes. This lets you release the start switch and the unit keeps running.
And can I test it without taking the motor out?
Removing the motor does not gain you anything. It is a pain to test because the motor has to be close to operating speed for it to close. The easiest way is to eliminate the thermostats, heater and timer. Then all that is left is the centrifugal switch. It is the one with the 2 larger red wires going to it.
You could also do a live test. With the drum removed measure across the switch. Start up the unit, if you see 240 volts across the switch it is toast.
This is easiest done with two people so you can concentrate on the meter leads and someone else can start the unit. Do not run the unit very long as it will blow the thermal cutout if the heater comes on. There is no air flow over the heating coils with the drum removed so they will overheat..
If you attempt this be very, very careful as 240 volts is lethal!!!
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced 3 parts.. Still can't figure out what's wrong! Neozen Dryer Repair 0 01-12-2011 10:32 PM
replaced parts but same problem tators Refrigerator & Freezer Repair 1 08-04-2010 03:08 PM
Whirlpoo Dryer won't heat, tested most parts everythingman Dryer Repair 1 08-09-2009 10:32 PM
No Oven Heat HELP parts replaced Kenmore Elite KiaTia Oven Repair (including Ranges and Cooktops) 0 07-25-2009 11:54 AM
Replaced all HV parts still have problem CJ14 Microwave Repair 0 01-16-2009 01:37 PM
