Discuss
Replacing Kenmore Dryer Door Switch
 in
Dryer Repair
My 11 yr old Kenmore Dryer will not stop buzzing when I shut the door. Is my door switch bad
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replacing Kenmore Dryer Door Switch
  #1 (permalink)
Old 03-19-2011, 08:32 AM
Junior Member
JCR12 is on a distinguished road
Default Replacing Kenmore Dryer Door Switch
Model Number: 11060612990   Brand: Kenmore   Age: More than 10 years
My 11 yr old Kenmore Dryer will not stop buzzing when I shut the door. Is my door switch bad or is it another problem?
If it is my door switch, how do I open the top of my Kenmore Electric Dryer
model 11060612990 to repair it?
Thank You.....Jim
Related Models
Kenmore 11060612990 ELECTRIC DRYER
Kenmore 1106062110 ELECTRIC DRYER
Kenmore 11060622990 ELECTRIC DRYER
Kenmore 11060702990 ELECTRIC DRYER
Kenmore 11060712990 ELECTRIC DRYER
Kenmore 11060722990 ELECTRIC DRYER
Kenmore 11060724990 ELECTRIC DRYER
Kenmore 11060727990 ELECTRIC DRYER
Kenmore 11060802990 ELECTRIC DRYER
Kenmore 11060812990 ELECTRIC DRYER
Kenmore 11060814990 ELECTRIC DRYER
Kenmore 11060817990 ELECTRIC DRYER
Kenmore 11060832990 ELECTRIC DRYER
Kenmore 11060842990 ELECTRIC DRYER
Kenmore 11060852990 ELECTRIC DRYER
Kenmore 11060854990 ELECTRIC DRYER
Kenmore 11060857990 ELECTRIC DRYER
Kenmore 11060882990 Dryer
Kenmore 11060884990 ELECTRIC DRYER
Kenmore 11060887990 KENMORE ELECTRIC DRYER
Kenmore 11060901990 ELECTRIC DRYER
Kenmore 11060902990 ELECTRIC DRYER
Kenmore 11060904990 ELECTRIC DRYER
Kenmore 11060907990 ELECTRIC DRYER
Kenmore 11060912990 ELECTRIC DRYER
Kenmore 11060922990 ELECTRIC DRYER
Kenmore 11060924990 ELECTRIC DRYER
Kenmore 11060927990 ELECTRIC DRYER
Kenmore 11060932990 ELECTRIC DRYER
Kenmore 11060936990 ELECTRIC DRYER
Kenmore 11060942990 DRYER
Kenmore 11060952990 ELECTRIC DRYER
Kenmore 11060954990 ELECTRIC DRYER
Kenmore 11060956990 ELECTRIC DRYER
Kenmore 11060957990 ELECTRIC DRYER
Kenmore 11060972990 ELECTRIC DRYER
Kenmore 11060982990 ELECTRIC DRYER
Kenmore 11060992990 ELECTRIC DRYER
Kenmore 11060994990 ELECTRIC DRYER
Kenmore 11060996990 ELECTRIC DRYER
Kenmore 11060997990 ELECTRIC DRYER
Kenmore 1106101100 KENMORE WRINGER WASHER
Kenmore 1106101400 KENMORE WRINGER WASHER
Kenmore 1106101401 KENMORE WRINGER WASHER
Kenmore 1106101402 KENMORE WRINGER WASHER
Kenmore 1106102300 KENMORE WRINGER WASHER
Kenmore 1106102500 KENMORE WRINGER WASHER
Kenmore 1106102501 KENMORE WRINGER WASHER
Kenmore 1106102600 KENMORE WRINGER WASHER
Kenmore 1106102601 KENMORE WRINGER WASHER
Kenmore 1106102700 KENMORE WRINGER WASHER
Kenmore 1106102701 KENMORE WRINGER WASHER
Kenmore 1106102702 KENMORE WRINGER WASHER
Kenmore 1106102710 KENMORE WRINGER WASHER
Kenmore 1106102711 KENMORE WRINGER WASHER
Kenmore 1106102720 KENMORE WRINGER WASHER
Kenmore 1106102800 KENMORE WRINGER WASHER
Kenmore 1106102801 KENMORE WRINGER WASHER
Kenmore 1106102802 KENMORE WRINGER WASHER
Kenmore 1106102850 KENMORE WRINGER WASHER
Kenmore 1106103000 KENMORE SEMI-AUTOMATIC WASHER
Kenmore 1106104200 KENMORE AUTOMATIC WASHER
Kenmore 1106104300 KENMORE AUTOMATIC WASHER
Kenmore 1106104350 KENMORE AUTOMATIC WASHER
Kenmore 1106104500 KENMORE AUTOMATIC WASHERS
Kenmore 1106104510 KENMORE AUTOMATIC WASHER
Kenmore 1106104520 KENMORE AUTOMATIC WASHER
Kenmore 1106104550 KENMORE AUTOMATIC WASHERS
Kenmore 1106104560 KENMORE AUTOMATIC WASHER
Kenmore 1106104570 KENMORE AUTOMATIC WASHER
Kenmore 1106104700 KENMORE AUTOMATIC WASHERS
Kenmore 1106104750 KENMORE AUTOMATIC WASHERS
Kenmore 1106104810 KENMORE AUTOMATIC WASHER
Kenmore 1106104860 KENMORE AUTOMATIC WASHER
Kenmore 1106105300 KENMORE AUTOMATIC WASHER
Kenmore 1106105350 KENMORE AUTOMATIC WASHER
Kenmore 1106105500 KENMORE AUTOMATIC WASHERS
Kenmore 1106105510 KENMORE AUTOMATIC WASHER
Kenmore 1106105520 KENMORE AUTOMATIC WASHER
Kenmore 1106105550 KENMORE AUTOMATIC WASHERS
Kenmore 1106105560 KENMORE AUTOMATIC WASHER
Kenmore 1106105570 KENMORE AUTOMATIC WASHER
Kenmore 1106105700 KENMORE AUTOMATIC WASHERS
Kenmore 1106105750 KENMORE AUTOMATIC WASHERS
Kenmore 1106105810 KENMORE AUTOMATIC WASHER
Kenmore 1106105860 KENMORE AUTOMATIC WASHER
Kenmore 11061062000 DRYER
Kenmore 11061064000 DRYER
Kenmore 11061066000 DRYER
Kenmore 1106107400 KENMORE GAS DRYER
Kenmore 1106107401 KENMORE GAS DRYER
Kenmore 1106107500 KENMORE GAS DRYER
Kenmore 1106107501 KENMORE GAS DRYER
Kenmore 1106107502 KENMORE GAS DRYER
Kenmore 1106107700 KENMORE GAS DRYER
Kenmore 1106107701 KENMORE GAS DRYER
Kenmore 1106107710 KENMORE GAS DRYER
Kenmore 1106107800 KENMORE GAS DRYER
Kenmore 1106107801 KENMORE GAS DRYER
Kenmore 1106107803 KENMORE GAS DRYER
Kenmore 11061082000 DRYER
Kenmore 1106108400 KENMORE ELECTRIC DRYER
Kenmore 11061084000 DRYER
Kenmore 1106108401 KENMORE ELECTRIC DRYER
Kenmore 1106108500 KENMORE ELECTRIC DRYER
Kenmore 1106108501 KENMORE ELECTRIC DRYER
Kenmore 11061086000 DRYER
Kenmore 1106108700 KENMORE ELECTRIC DRYER
Kenmore 1106108701 KENMORE ELECTRIC DRYER
Kenmore 1106108710 KENMORE ELECTRIC DRYER
Kenmore 1106108800 KENMORE ELECTRIC DRYER
Kenmore 1106108801 KENMORE ELECTRIC DRYER
Kenmore 1106108802 KENMORE ELECTRIC DRYER
Kenmore 1106109100 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109101 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109102 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109105 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 11061092000 DRYER
Kenmore 1106109500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109501 KENMORE GAS COMBINATION WASHER-DRYER
  #2 (permalink)
Old 03-19-2011, 09:11 AM
Junior Member
mrcelli18 is on a distinguished road
Default
May need a new door switch..to open the top on most dryer's...there are clips above the door mounted in the top panel in each corner..(right at the seam where the front and top panels meet on the dryer) just use something flat to push the clips and lift the top(one corner at a time).
Note :unplug the dryer
  #3 (permalink)
Old 03-19-2011, 11:05 AM
Junior Member
Default
Thanks for the advice M Celli.
If not the door switch what other dryer part would need to be replaced to
stop the buzzing noise when the dryer door is closed?
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing door switch on Roper/Whirlpool Dryer kamnet Dryer Repair 5 05-18-2011 05:15 PM
Replacing door switch on Whirlpool Dryer bota Dryer Repair 3 10-19-2010 03:48 AM
Replacing a door switch on a sears HE3t imref Washer Repair 1 11-30-2009 06:00 PM
Replacing Refrigerator Door Switch... msmma Refrigerator & Freezer Repair 0 11-04-2009 10:34 AM
How do I replace a Kenmore Stackable Dryer Door Switch? username6454 Dryer Repair 1 05-15-2009 01:18 PM
