| » Maytag Admiral Stopped Mid Cycle |
Model Number: LNC7764A71 Brand: Maytag Age: 1 - 5 years
I've checked our circuit breaker and seems to be fine.
the drum turns both ways fine. I've cleaned the lint from almost every possible area and still nothing when i push the start dial nothing happens and i hear a verry soft winding noise (when very close to dial) probably just the timer. How do i tell if its the door switch? It clicks and has resistance to it when i push in so i don't think that is the problem. The model # is LNC7764A71 Serial # 12245913EC It is a Maytag (Capacity Plus) Admiral My father is a very capable Diesel Mechanic we really just need some help Identifying the cause of why it stopped Any help would be appreciated, thank you very much. Ads By Google Related Models |
Quote:
Darren, the first palce you need to start checking, on that style unit with your complaint, is the heater thermal fuse/hi limit thermostat. Part number: AP4242472 You'll need to raise the top of the dryer, and you'll find the components mounted to the heater assembly in the left rear corner of the cabinet. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag stopped on spin cycle, smelled hot | Shelly Z | Washer Repair | 0 | 06-15-2010 07:28 PM |
| Maytag front loader stopped mid cycle and won't start again | sassy_33629 | Washer Repair | 0 | 06-01-2010 07:33 AM |
| Maytag washer stopped in middle of cycle full of water | Dwells | Washer Repair | 2 | 02-15-2010 04:28 PM |
| Maytag stopped agitating during wash cycle | zetlan | Washer Repair | 1 | 01-19-2010 05:37 PM |
| Maytag washer stopped working mid cycle | jtr1684 | Washer Repair | 1 | 01-07-2010 03:02 PM |
