cfcdh3
#1 Posted : Tuesday, March 15, 2011 5:45:45 PM(UTC)
cfcdh3
Hello. I have a Whirlpool Cabrio electric dryer model #WED6400SW1 that is putting out low heat regardless of the control settings. I checked the heat duct with a infrared thermometer and it's reading between 120-125 degrees F. Internal drum temprature is only 85 degrees F. What is the troubleshooting process? Thank you.
#2 Posted : Wednesday, March 16, 2011 3:03:19 AM(UTC)
Replacement parts for WHIRLPOOL WED6400SW1 29`` ELECTRIC DRYER | AppliancePartsPros.com
And here is a service manual
Whirlpool 8178584 Cabrio Dryer Service Manual - ApplianceDigest.com
You will have to join the site to get the manual but it is a good site for info for the appliance DIYer.
Probably would not be a bad idea to check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Try running the diagnostics to see if an error comes up.
Check the heating coil.
Unplug the unit and remove both wires from the heating coil.
Then measure it with a meter, should be around 10 ohms.
Then measure from each connector to the case, both should be infinite ohms (open).
If not it could be the coil is grounded and is causing problems.
If OK
Check both thermostats with a meter, see the tech sheet.
File Attachment(s):
WED6400.pdf (421kb) downloaded 48 time(s).
kayakcrzy
#3 Posted : Wednesday, March 16, 2011 3:51:01 AM(UTC)
kayakcrzy
Sitting on the blower housing is a part called a thermisiter. It's job is to measure temperature. I have a feeling that will be your issue. The part # is 8577274. Tom ApplianceEducator.com
cfcdh3
#4 Posted : Wednesday, March 16, 2011 2:02:17 PM(UTC)
cfcdh3
Thank you Sir. Any way to test it?
cfcdh3
#5 Posted : Wednesday, March 16, 2011 2:03:53 PM(UTC)
cfcdh3
Originally Posted by: denman Go to Quoted Post
If OK
If OK
If OK
Wow... Thank you for the great reply and information. I was asking myself how to run the diagnostic, then I saw you attached the tech sheet. It may be a couple of days before I get to work on it (again, it's drying lukewarm), but will let everyone know what the final problem was. Thanks again.
cfcdh3
#6 Posted : Tuesday, March 22, 2011 4:12:29 PM(UTC)
cfcdh3
Finally got the parts and repaired today. Dual heating element was burned up pretty bad and falling apart. EXPENSIVE ($125). Also replaced high limit switch and both thermisiters. All is well for now. Thanks again for the tech info and advice.
#7 Posted : Wednesday, March 23, 2011 12:57:53 AM(UTC)
You are welcome, glad to hear you are up and running.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
