Discuss
Maytag Dryer Start/Pause LED
 in
Dryer Repair
The dryer will not turn on. I notice the start/pause led continues to flash. coincidentally, sometimes when I touch both
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer Start/Pause LED
  #1 (permalink)
Old 03-15-2011, 08:08 AM
Junior Member
BHcub is on a distinguished road
Default Maytag Dryer Start/Pause LED
Model Number: MDG5500AWW   Brand: Maytag   Age: More than 10 years
The dryer will not turn on. I notice the start/pause led continues to flash. coincidentally, sometimes when I touch both signal keys and then the start/pause key the dryer turns on. I can do a Membrane pad check and all LED's toggle on and off. Any thoughts on what to replace?
Related Models
Maytag MDG5500AWW DRYER- GAS
Maytag MDG5806AWK DRYER- GAS
Maytag MDG5806AWW DRYER- GAS
Maytag MDG5960BWW DRYER- GAS
Maytag MDG6000AWQ DRYER- GAS
Maytag MDG6000AWW DRYER- GAS
Maytag MDG6000AXW DRYER- GAS
Maytag MDG6000BWQ DRYER- GAS
Maytag MDG6000BWW DRYER- GAS
Maytag MDG6200AWQ DRYER- GAS
Maytag MDG6200AWW DRYER- GAS
Maytag MDG6400AWQ DRYER- GAS
Maytag MDG6400AWW DRYER- GAS
Maytag MDG6460AWW DRYER- GAS
Maytag MDG6657BWQ DRYER- GAS
Maytag MDG6657BWW DRYER- GAS
Maytag MDG6700AWM DRYER- GAS
Maytag MDG6700AWW DRYER- GAS
Maytag MDG6800AWQ DRYER- GAS
Maytag MDG6800AWW DRYER- GAS
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
  #2 (permalink)
Old 03-16-2011, 08:35 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
BH,
First check, that the door switch sense circuit is correct.
On PCB, disconnect the BB2 connector from the board,
With the power supplied to the unit and the door closed, you should read 120 VAC across the Red and White wires in the connector.
(open and close the door several times to insure theres not an intermittent contact).
Disconnect the touchpad ribbon(J3) from the PCB connector.
** pin no. 1 is on the bottom and pin 2 is blank)
On the ribbon, put your meter leads on tracer no, 3 and tracer no. 7, when you press the "start/pause" pad you should read 10,000 ohms resistance across the ribbon pins.
(perform several tests, to insure no intermittent circuits).
I'm sure you'll find your problem in one of these areas(most likely the touchpad assembly).
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer just pause after approx 10 sec comack Dryer Repair 0 03-11-2011 02:31 PM
Maytag washer start/pause push pad not working patmward08 Washer Repair 2 08-17-2010 06:58 AM
Maytag Dryer won't start ssp123 Dryer Repair 2 02-16-2010 07:06 PM
ge washer stays in drain w/ imin showing & Code E31 & start/pause blinks sometimes Appliabespecialists Washer Repair 3 02-08-2010 10:14 AM
maytag dryer will not start Kevin B Dryer Repair 2 10-14-2009 02:28 PM
