Farley
#1 Posted : Monday, March 14, 2011 6:46:15 AM(UTC)
Farley
I have a Maytag dryer model MDE3000AYW. The drum won't turn.
I've taken the drum belt off and tried to run the motor. The motor shaft turns about 1/8 of a revolution, clicks and then repeats the cycle.
Is the motor bad? Are the bearings bad? Can the bearings be replaced without replacing the motor?
Thanks!
#2 Posted : Tuesday, March 15, 2011 1:39:58 AM(UTC)
Replacement parts for MAYTAG MDE3000AYW DRYER- ELE | AppliancePartsPros.com
[COLOR="DarkRed"]Is the motor bad? Are the bearings bad? [/COLOR]
Yes, it does sound like a bad motor.
I do not think that it is bad bearings.
Sounds like the main winding may be burned out (open).
[COLOR="DarkRed"]Can the bearings be replaced without replacing the motor?[/COLOR]
No, you have to replace the motor.
