Discuss
Kenmore Electric Dryer Intermittent Heat question
 in
Dryer Repair
Question about the dryer heating cycle, does the heating element cycle on and off during timed drying? I have a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Electric Dryer Intermittent Heat question
  #1 (permalink)
Old 12-30-2008, 10:30 AM
Junior Member
bolingmike is on a distinguished road
Default Kenmore Electric Dryer Intermittent Heat question
Model Number: 110-62622101   Brand: Kenmore   Age: 1 - 5 years
Question about the dryer heating cycle, does the heating element cycle on and off during timed drying? I have a Kenmore Model 110-62622101 Serial # MP1188089 Heavy Duty Super Capacity dryer that started drying our clothes intermittently. I removed the vent hose and checked it for blockage and there was none, I removed the back from the dryer, removed the lint trap shute that covers the blower motor and cleaned it and then replaced. Cleaned all lint from all parts of the dryer. With back of dryer still removed, plugged the dryer into the power outlet and noticed that with the drying setting on timed high heat and the power button pushed there is good air flow, but the heating element does not start to glow imediately, it takes a few seconds to start to glow and then will stay glowing for about 1 to 2 minutes and turn off and then turn back on in about 1 to 2 more minutes. Is this correct operation for the heating element? If not, could someone please advise on what to test first?
Thanks Mike
Ads By Google
Related Models
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Sears 110.16202691  AUTOMATIC WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Hoover 1100
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
  #2 (permalink)
Old 02-21-2009, 04:04 AM
Junior Member
krausjw is on a distinguished road
Default
Don't know if it's too late to help or not. I had the exact same problem with a Kenmore 70 series dryer. The fix that worked was to replace the gave valve coils. There are two of them to replace and they are sold as a set.
I'm no expert but my understanding is that they can't be tested, so you have to gamble some by replacing them. I had tried several other fixes which did not work so the coils were next. Cost for the replacement set was $30.
Hope this helps.
  #3 (permalink)
Old 02-23-2009, 06:46 AM
Junior Member
Default
krausjw
Thanks for the reply, but I think the Gave Valve colis is on a gas dryer but not sure, but anyways my dryer is electric.
  #4 (permalink)
Old 02-23-2009, 06:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by bolingmike View Post
...but the heating element does not start to glow imediately, it takes a few seconds to start to glow and then will stay glowing for about 1 to 2 minutes and turn off and then turn back on in about 1 to 2 more minutes. Is this correct operation for the heating element?...
Mike,
This is exactly how it should work. It heats up to the proper temperature then shuts off, cools down for about 25°F-30°F and then turns back on.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer intermittent heat rpuglia Dryer Repair 3 09-30-2009 01:33 PM
No Heat On Kenmore Electric Dryer gmamon Dryer Repair 5 08-27-2009 09:37 PM
2003 Kenmore Dryer : Intermittent Heat jeffsuwanee Dryer Repair 1 07-24-2009 07:22 AM
Kenmore dryer has intermittent heat acillatem Dryer Repair 5 12-22-2008 05:55 PM
Kenmore Electric Dryer-No Heat jbarbers Dryer Repair 3 04-17-2008 08:53 AM
