I have a whirpool dryer that works fine but will not shut off at the end of a cycle,it just keeps going till i open the door or turn it to off. It will restart if I push the start button. Does not matter if it is on timed dry or on the moisture senser dry. Will replacing the timer help?
Originally Posted by: De Haan I have a whirpool dryer that works fine but will not shut off at the end of a cycle,it just keeps going till i open the door or turn it to off. It will restart if I push the start button. Does not matter if it is on timed dry or on the moisture senser dry. Will replacing the timer help? it is the timer motor, check the contnuity on it
so how do I check the continuity. I have a digital multimeter. With the unit unplugged and the timer set to dry and testing the the largest two wires it reads 0. reads 1 if timer is turned off.
