| » dryer won't heat similar to other post's |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: LEQ6848AQ3 Brand: Whirlpool Age: 5 - 10 years
I saw Gene's recommendation to the dryer heating problem of Whirlpool 5yr old model. I have the same problem. Thermal Fuse as that same one, numbers match, but the Cycling Thermostat looks completely different than the picture provided at the parts page. On this model the Thermostat has 5 wires coming off of it as apposed the the two as shown on the parts page. I intend to get the fuse tested but will need the part number for the thermostat if replacement is required. As you said its recommended the thermostat be changed if the fuse blows.
Check your ducting in the house for lint buildup. They sell a linteater 4 inch brush for this.
Check heater thermal fuse, if blown out, you can order a thermal fuse/overload thermostat pn 279973
__________________
| Display Modes | |
| Gas Dryer no Heat | KrazyK55 | Dryer Repair | 6 | 01-15-2008 01:22 PM |
| Dryer will run but not heat | allansc | Dryer Repair | 12 | 12-28-2007 06:10 PM |
| dryer no heat | pdowney | Dryer Repair | 2 | 10-18-2007 06:32 AM |
| dryer will not heat | ctct703 | Dryer Repair | 1 | 09-28-2007 02:00 AM |
| dryer heat | karen | Dryer Repair | 0 | 07-23-2007 12:55 PM |
