Could not find a JQS so am using JQ1, it should be a very close match.
Replacement parts for WHIRLPOOL TEDS740JQ1 | AppliancePartsPros.comSee attachment for the wiring diagram.
Your problem could be a number of things.
First I would check the heating coil to make sure it is not grounded.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate.
Next I would check the main thermostat's (Item 8 in Section 3) internal heater, it should be 6,000 to 8,000 ohms. It is turned on for lower heat settings, adding heat to the thermostat and therefore lowering the unit's heat output.
If both are OK then I would replace the main thermostat as that is the most likely cause (contacts welded together).
If you want to confirm this you could heat it up on a stove to see if it will open. I use my soldering gun.
