Discuss
Gas dryer starts fine gas flame runs 10-15 min and then quits
 in
Dryer Repair
I have a Tappen gas dryer, I start it, the igniter comes on, then the gas kicks on and it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer starts fine gas flame runs 10-15 min and then quits
  #1 (permalink)
Old 10-22-2007, 05:24 PM
Krsolo Krsolo is offline
Junior Member
Krsolo is on a distinguished road
Default Gas dryer starts fine gas flame runs 10-15 min and then quits
Brand: Tappan   Age: More than 10 years
I have a Tappen gas dryer, I start it, the igniter comes on, then the gas kicks on and it lites up fine, it runs great for about 10 min. and then the flame goes out (I assume its a normal cycling as the heat reaches a certain temp) but then after a minute or so the igniter comes on again but the gas valve doesnt trigger, the igniter then cycles off and then comes on again after a bit, but again the gas valve doesnt open. If I shut it off and try it after an hour or so it will trigger correctly and the gas comes on and lites properly, would this be a faulty flame sensor part no. Q600651 that is located about 4-6'' up the tube or is it something else?
Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-22-2007, 05:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Krsolo
The problem with your dryer is a bad coils on the gas valve. Replacing them will solve the problem.
Set of the coils
- The part number for the set of the gas valve coils AP2150379
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-23-2007, 07:30 AM
Junior Member
Default
Thank you, I will get them ordered!
  #4 (permalink)
Old 10-23-2007, 09:44 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 09:23 PM
dryer quits running after a short time magictickler Dryer Repair 1 10-01-2007 03:48 AM
Dryer starts then stops Redwings19 Dryer Repair 0 09-20-2007 10:09 AM
Dishwasher quits at random times pwisor Dishwasher Repair 0 09-04-2007 11:13 AM
Dryer makes rumbling sound when starts Scottnvegas Dryer Repair 3 08-12-2007 09:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
