There is no heat in the dryer. Everything else seems to work.
Here are your parts includes a wiring diagram Replacement parts for MAYTAG PYE3300AYW DRYER- ELE | AppliancePartsPros.comThe first thing to check is the power. The motor and light both use 120 volts but the heating element requires the full 240 volts. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. [COLOR="Red"] Be careful as 240 volts is lethal !!! [/COLOR] If power is OK then unplug the unit and check the heater and thermostats using a meter. Heater should be 10 to 12 ohms all thermostats should be 0 ohms. |
THIS FORUM IS DEAD!!!!!!! |
