| » Dryer will not stay hot |
Model Number: LGR8648LWO Brand: Whirlpool Age: 5 - 10 years
Dryer does not heat up. What needs to be replaced/repaired?
Jano,
I presume, there is no heat at all ? You're sure you have a heat setting selected on the temperature control knob ? You're sure you have gas supplied and turned on to the dryer ? Try this, so we'll have a better idea of which direction to take, On the lower left side of the front panel, you'll find a 1in X 1in square,removable plastic cover, carefully remove the cover using a putty knife,butter knife, etc. ( the plastic cover removed, will give you a way of observing the ignition process). Put the dryer into a dry cycle with hi heat selected, and start the dryer. Through the observation openning, you should see: An orange glow(from the igniter). After 30 to 40 seconds, the orange glow should start to fade. In less than a second, you should be able to see or hear the gas ignite. You may need to observe this process for a few minutes(10 to 15)if all the above occur. If nothing occurs, you'll need a multi meter, so we can check thermostats, glow bar, and sensors,etc. We'll keep an eye out for your update response, and we can get going from there.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Dryer won't stay on | amabear | Dryer Repair | 1 | 02-25-2011 04:39 PM |
| Dryer won't stay hot | kmiller007 | Dryer Repair | 0 | 01-17-2011 07:27 PM |
| Dryer Will Not Stay Hot | michaelhall | Dryer Repair | 0 | 04-06-2010 03:27 PM |
| dryer won't stay on | mtamplin | Dryer Repair | 1 | 05-03-2009 05:46 PM |
| Dryer does not stay on | BigDro | Dryer Repair | 0 | 03-10-2009 03:59 PM |
