Discuss
whirlpool 29" dryer
 in
Dryer Repair
The flame on my dryer shuts off after about 3-4 minutes and does not come back on until it sits
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool 29" dryer
  #1 (permalink)
Old 12-26-2008, 01:54 PM
Junior Member
marinefish is on a distinguished road
Default whirlpool 29" dryer
Model Number: LGQ8800JQ2   Brand: Whirlpool   Age: 5 - 10 years
The flame on my dryer shuts off after about 3-4 minutes and does not come back on until it sits for a few minutes and is turned back on. If you set it for a half hour or so it will run, the flame will go off and the dryer will continue to run with no flame and not dry the cloths.
I have replaced the following: #32 radiant sensor 338906, #9 Internal-bias thermostat 8318268, #7 thermal fuse 3392519, #15 thermostat 205*F 3403140, #4 ignitor 686590.
After replacing all of these parts it still will not keep the flame going longer then about 3-4 minutes. What other parts can I replace that will fix the problem? Thanks, George
Ads By Google
Related Models
Whirlpool LGQ8800JQ2 DRYER
Whirlpool LGQ8800JT0 GAS DRYER
Whirlpool LGQ8800JT1 DRYER
Whirlpool LGQ8800JT2 DRYER
Whirlpool LGQ8857HQ0 DRYER
Whirlpool LGQ8857HQ1 GAS DRYER
Whirlpool LGQ8857HZ0 DRYER
Whirlpool LGQ8857HZ1 GAS DRYER
Whirlpool LGQ8857JQ0 GAS DRYER
Whirlpool LGQ8857JQ1 DRYER
Whirlpool LGQ8857JQ2 DRYER
Whirlpool LGQ8857JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8857JT0 GAS DRYER
Whirlpool LGQ8857JT1 DRYER
Whirlpool LGQ8857JT2 DRYER
Whirlpool LGQ8857JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858HQ0 GAS DRYER
Whirlpool LGQ8858HQ1 GAS DRYER
Whirlpool LGQ8858HZ0 GAS DRYER
Whirlpool LGQ8858HZ1 GAS DRYER
Whirlpool LGQ8858JQ0 GAS DRYER
Whirlpool LGQ8858JQ1 DRYER
Whirlpool LGQ8858JQ2 DRYER
Whirlpool LGQ8858JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8858JT0 GAS DRYER
Whirlpool LGQ8858JT1 DRYER
Whirlpool LGQ8858JT2 DRYER
Whirlpool LGQ8858JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858JZ0 GAS DRYER
Whirlpool LGQ8858JZ1 DRYER
Whirlpool LGQ8858JZ2 DRYER
Whirlpool LGQ9030PQ0 29"GAS DRYER
Whirlpool LGQ9030PQ1 29"GAS DRYER
Whirlpool LGQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9508KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9508LG0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW1 29"GAS DRYER
Whirlpool LGQ9508PG0 29"GAS DRYER
Whirlpool LGQ9508PG1 29"GAS DRYER
Whirlpool LGQ9508PW0 29"GAS DRYER
Whirlpool LGQ9508PW1 29"GAS DRYER
Whirlpool LGQ9557KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9557KT0 RESIDENTIAL DRYER
Whirlpool LGQ9557KT1 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9558KT0 RESIDENTIAL DRYER
Whirlpool LGQ9558KT1 RESIDENTIAL DRYER
Whirlpool LGQ9857LG0 RESIDENTIAL DRYER
Whirlpool LGQ9857LG1 29"GAS DRYER
Whirlpool LGQ9857LW0 RESIDENTIAL DRYER
Whirlpool LGQ9857LW1 29"GAS DRYER
Whirlpool LGQ9857PW0 29"GAS DRYER
Whirlpool LGQ9858LG0 RESIDENTIAL DRYER
Whirlpool LGQ9858LG1 29"GAS DRYER
Whirlpool LGQ9858LW0 RESIDENTIAL DRYER
Whirlpool LGQ9858LW1 29"GAS DRYER
Whirlpool LGQ9858PG0 29"GAS DRYER
Whirlpool LGQ9858PG1 29"GAS DRYER
Whirlpool LGQ9858PW0 29"GAS DRYER
Whirlpool LGQ9858PW1 29"GAS DRYER
Whirlpool LGR2614BW0 GAS DRYER
Whirlpool LGR2614BW1 GAS DRYER
Whirlpool LGR2614BW2 GAS DRYER
Whirlpool LGR2614DW0 GAS DRYER
Whirlpool LGR2614DW1 GAS DRYER
Whirlpool LGR2614EW0 GAS DRYER
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB RANGE- S/C F/S GAS
Admiral LGR3330ADW RANGE- S/C F/S GAS
Admiral LGR3330ADZ RANGE- S/C F/S GAS
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0 Residential Dryer
Whirlpool LGR3424AW0 Residential Dryer
Whirlpool LGR3622BN0 COMPACT GAS DRYER
Whirlpool LGR3622BW0 COMPACT GAS DRYER
Whirlpool LGR3622DQ1 COMPACT GAS DRYER
Whirlpool LGR3622DZ1 COMPACT GAS DRYER
Whirlpool LGR3624BN2 GAS DRYER
Whirlpool LGR3624BW0 GAS DRYER
Whirlpool LGR3624BW1 GAS DRYER
Whirlpool LGR3624BW2 GAS DRYER
Whirlpool LGR3624DQ1 GAS DRYER
Whirlpool LGR3624EQ0 GAS DRYER
Whirlpool LGR3624EQ1 GAS DRYER
Whirlpool LGR3624EQ2 GAS DRYER
Whirlpool LGR3624JQ0 GAS DRYER
Whirlpool LGR3624JQ1 RESIDENTIAL DRYER
Whirlpool LGR3624JQ2 29" GAS DRYER
Whirlpool LGR3624JQ3 29" GAS DRYER
Whirlpool LGR3624PQ0 29" GAS DRYER
Whirlpool LGR3624PQ1 29" GAS DRYER
Whirlpool LGR3634EW0 GAS DRYER
Whirlpool LGR3634EW1 GAS DRYER
Whirlpool LGR3634EW2 GAS DRYER
Whirlpool LGR3634EW3 GAS DRYER
Whirlpool LGR3634JW0 GAS DRYER
Whirlpool LGR3634JW1 RESIDENTIAL DRYER
Whirlpool LGR3634JW2 GAS DRYER
Admiral LGR3725ADC RANGE- S/C F/S GAS
Whirlpool LGR4434AN0 GAS DRYER
Whirlpool LGR4434AN1 GAS DRYER
Whirlpool LGR4434AQ0 Residential Dryer
Whirlpool LGR4434AQ1 GAS DRYER
Whirlpool LGR4434AW0 Residential Dryer
Whirlpool LGR4434AW1 GAS DRYER
Whirlpool LGR4436AW0 Residential Dryer
Whirlpool LGR4600PQ0 29" GAS DRYER
Whirlpool LGR4600PQ1 29" GAS DRYER
Whirlpool LGR4624BN0 GAS DRYER
Whirlpool LGR4624BN1 GAS DRYER
Whirlpool LGR4624BN2 GAS DRYER
Whirlpool LGR4624BQ0 GAS DRYER
Whirlpool LGR4624BQ1 GAS DRYER
Whirlpool LGR4624BQ2 GAS DRYER
Whirlpool LGR4624BW0 GAS DRYER
Whirlpool LGR4624BW1 GAS DRYER
Whirlpool LGR4624BW2 GAS DRYER
  #2 (permalink)
Old 12-26-2008, 03:26 PM
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
Replace the solonoids on the gas valve, I have seen many of then that will fire the first time and then not again until fully cooled down.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Microwave does not work gives "door" error jokerwild Microwave Repair 13 04-26-2013 11:49 AM
Kenmore/Whirlpool Duet "oil canning" gjferg Washer Repair 4 09-17-2012 06:37 PM
Whirlpool Double Oven "E6 F2" Error nessiedsj Oven Repair (including Ranges and Cooktops) 1 11-21-2009 01:43 PM
Kenmore (Whirlpool) washer "bang" noise when spinning dadasmatta Washer Repair 6 09-25-2009 05:54 AM
Kenmore/Whirlpool -- "normal" operations dewings Washer Repair 2 05-08-2009 11:06 AM
