Discuss
Kenmore Washer+Dryer, Dryer not working
 in
Dryer Repair
I've got a Kenmore stacking Washer+Dryer Unit, and the Dryer stopped working the other night (washer still spins/ect). I've tested
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Washer+Dryer, Dryer not working
  #1 (permalink)
Old 03-04-2011, 12:23 PM
Junior Member
Sgat8516 is on a distinguished road
Default Kenmore Washer+Dryer, Dryer not working
Model Number: 11088762793   Brand: Kenmore   Age: 1 - 5 years
I've tested checked the breaker. I've tested continuity on the Start button and door switches (and the 4? Thermostats/Thermal Fuse inside), and I get resistance on all of them.
Any suggestions on what to check next?
I've been using the following parts diagram to locate the components:
http://www.********************************.com/part...od=11088762793
In Dryer Bulkhead diagram, are the parts I've checked 42 47 48 50 (internal bias operating thermostat, Thermal cutoff fuse kit, high limit thermostat, thermal limiter), plus the door and on switches.
Ads By Google
Related Models
Kenmore 11088762793 LAUNDRY CENTER
Kenmore 11088764790 LAUNDRY CENTER
Kenmore 11088764791 LAUNDRY CENTER
Kenmore 11088764792 LAUNDRY CENTER
Kenmore 11088764793 LAUNDRY CENTER
Kenmore 11088870100 ELECTRIC DRYER
Kenmore 11088870110 ELECTRIC DRYER
Kenmore 11088870111 ELECTRIC DRYER
Kenmore 11088870120 ELECTRIC DRYER
Kenmore 11088870300 ELECTRIC DRYER
Kenmore 11088870600 ELECTRIC DRYER
Kenmore 11088870700 ELECTRIC DRYER
Kenmore 11088870800 ELECTRIC DRYER
Kenmore 11088870810 ELECTRIC DRYER
Kenmore 11088870811 ELECTRIC DRYER
Kenmore 11088870820 ELECTRIC DRYER
Kenmore 11089182990 ELECTRIC DRYER
Kenmore 11089390830 ELECTRIC DRYER
Kenmore 11089416120 GAS DRYER
Kenmore 11089416130 GAS DRYER
Kenmore 11089416320 GAS DRYER
Kenmore 11089416330 GAS DRYER
Kenmore 11089416620 GAS DRYER
Kenmore 11089416630 GAS DRYER
Kenmore 11089416720 GAS DRYER
Kenmore 11089416730 GAS DRYER
Kenmore 11089416820 GAS DRYER
Kenmore 11089416830 GAS DRYER
Kenmore 11089417100 GAS DRYER
Kenmore 11089417300 GAS DRYER
Kenmore 11089417600 GAS DRYER
Kenmore 11089417700 GAS DRYER
Kenmore 11089417800 GAS DRYER
Kenmore 11089419100 GAS DRYER
Kenmore 11089419110 GAS DRYER
Kenmore 11089419111 GAS DRYER
Kenmore 11089419120 GAS DRYER
Kenmore 11089419300 GAS DRYER
Kenmore 11089419600 GAS DRYER
Kenmore 11089419700 GAS DRYER
Kenmore 11089419800 GAS DRYER
Kenmore 11089419810 GAS DRYER
Kenmore 11089419811 GAS DRYER
Kenmore 11089419820 GAS DRYER
Kenmore 11089519800 GAS DRYER
Kenmore 11089675110 WASHER/DRYER
Kenmore 11089722990 ELECTRIC DRYER
Kenmore 11089722991 ELECTRIC DRYER
Kenmore 11091110100 AUTOMATIC WASHER
Kenmore 11091110110 AUTOMATIC WASHER
Kenmore 11091121100 AUTOMATIC WASHER
Kenmore 11091121110 AUTOMATIC WASHER
Kenmore 11091210100 AUTOMATIC WASHER
Kenmore 11091220100 AUTOMATIC WASHER
Kenmore 11091250100 AUTOMATIC WASHER
Kenmore 11091263100 AUTOMATIC WASHER
Kenmore 11091263600 AUTOMATIC WASHER
Kenmore 11091263800 AUTOMATIC WASHER
Kenmore 11091264100 AUTOMATIC WASHER
Kenmore 11091264600 AUTOMATIC WASHER
Kenmore 11091264800 AUTOMATIC WASHER
Kenmore 11091278100 AUTOMATIC WASHER
Kenmore 11091278600 AUTOMATIC WASHER
Kenmore 11091278800 AUTOMATIC WASHER
Kenmore 11091310100 AUTOMATIC WASHER
Kenmore 11091320100 AUTOMATIC WASHER
Kenmore 11091468100 AUTOMATIC WASHER
Kenmore 11091468600 AUTOMATIC WASHER
Kenmore 11091468800 AUTOMATIC WASHER
Kenmore 11091510100 WASHER
Kenmore 11091510110 WASHER
Kenmore 11091511100 WASHER
Kenmore 11091511110 WASHER
Kenmore 11091512200 WASHER
Kenmore 11091512210 WASHER
Kenmore 11091520100 WASHER
Kenmore 11091520110 WASHER
Kenmore 11091521200 WASHER
Kenmore 11091521210 WASHER
Kenmore 11091522200 WASHER
Kenmore 11091550100 WASHER
Kenmore 11091551200 WASHER
Kenmore 11091551210 WASHER
Kenmore 11091552200 WASHER
Kenmore 11091552210 AUTOMATIC WASHER
Kenmore 11091554100 WASHER
Kenmore 11091554110 WASHER
Kenmore 11091554200 WASHER
Kenmore 11091554210 WASHER
Kenmore 11091564100 WASHER
Kenmore 11091564110 WASHER
Kenmore 11091564800 WASHER
Kenmore 11091564810 WASHER
Kenmore 11091565100 WASHER
Kenmore 11091565110 AUTOMATIC WASHER
Kenmore 11091565200 WASHER
Kenmore 11091565210 AUTOMATIC WASHER
Kenmore 11091565800 WASHER
Kenmore 11091565810 AUTOMATIC WASHER
Kenmore 11091566200 WASHER
Kenmore 11091566210 WASHER
Kenmore 11091566400 WASHER
Kenmore 11091566410 WASHER
Kenmore 11091578100 WASHER
Kenmore 11091578800 WASHER
Kenmore 11091579100 WASHER
Kenmore 11091579800 WASHER
Kenmore 11091587200 WASHER
Kenmore 11091587210 WASHER
Kenmore 11091587400 WASHER
Kenmore 11091587410 WASHER
Kenmore 11092060100 AUTOMATIC WASHER
Kenmore 11092060110 AUTOMATIC WASHER
Kenmore 11092060120 AUTOMATIC WASHER
Kenmore 1109206110 AUTOMATIC WASHER
Kenmore 11092071100 AUTOMATIC WASHER
Kenmore 11092071110 AUTOMATIC WASHER
Kenmore 11092071300 AUTOMATIC WASHER
Kenmore 11092071310 AUTOMATIC WASHER
Kenmore 11092071600 AUTOMATIC WASHER
  #2 (permalink)
Old 03-04-2011, 06:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you check the belt and belt switch (#4 on the diagram)?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-04-2011, 09:49 PM
Junior Member
Default
Quote:
The entire dryer doesn't turn on. No motor, no noises, no nothing. But the washer works fine, and it only has 1 plug for both.
Would the belt switch cause that?
Btw, if it helps, it was running at the time it stopped working.
  #4 (permalink)
Old 03-07-2011, 06:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The belt switch controls voltage to the motor, so if the belt breaks or the switch itself becomes bad then the motor would not run.
__________________
  #5 (permalink)
Old 03-08-2011, 03:43 PM
Junior Member
Default
Ok, I think you may be onto something here. Its in a horrendously awkward position. I couldn't get access to the bolts that hold it in, but got the multimeter leads to make contact, and didn't show any contact at all between the leads (obviously need to get it out for verification).
Is there a special tool to take the blower wheel off? Looks square, larger than a standard socket wrench head. Can't break the contact by hand.
  #6 (permalink)
Old 03-08-2011, 08:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Reach behind the blower housing and place a 7/8’’ open end wrench on the motor. Rotate the blower wheel clockwise to lock the motor shaft with the wrench. Allow wrench to lock against the motor bracket.
Using a 3/8’’ socket drive with a 3/8’’ -1/2’’ adapter or 1/2’’ drive, remove the blower wheel. The blower wheel has left-hand threads. Rotate the wheel clockwise to remove. Directional arrows are molded on the front edge of the wheel showing which way to turn to loosen and tighten.
__________________
  #7 (permalink)
Old 03-10-2011, 11:43 AM
Junior Member
Default
Quote:
Its a 3/4, which is why its a problem. Checked Advance Auto for a suited rental tool, but they don't carry a 1/2 to 3/4 adapter.
Checking with a mechanic up the street in just a minute to see if he has one I can borrow.
Ok, got the fan wheel off, and its not the fan switch...
Anything else? Motor? How would i test it (now that i had to take the entire thing out, just to remove the belt switch...)
  #8 (permalink)
Old 03-11-2011, 08:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check all wires and wire harness plugs between the washer and the dryer.
Check the motor windings for continuity (4 to 6 ohms).
__________________
  #9 (permalink)
Old 03-28-2011, 01:06 PM
Junior Member
Default
Turned out to be (from my limited understanding of repair guy), was an electrical overload on a wire coming off the Motor, that also blew out a fuse (was only getting 120v, so enough for washer...)
But.. now the dryer runs fine, but takes 2x as long to dry a load...... vent's not blocked, dryer does warmup (not super hot though).
Its possible a wire would be switched around on the thermostats/thermistors (but I marked 1 wire for each, so I 'think' i put them on right). A few are pretty much symetrical, with no distinctions between up/down (so they'd go on the same way rightside up or upside down, and may have been switched).
Part 50 in below diagram (Thermal Limiter 195f), is one that especially might be a culprit (the one that has 4 wires coming out of it, as the entire device might have been put in upside down). It looks almost identical to the regular thermostats, except it has 4 wires (2 grey i think, and normal red+black?, with the red+black having a plastic cover around the plug's)
http://www.********************************.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsd irect.com%2flis_png%2fPLDM%2fP0212188-00004.png
  #10 (permalink)
Old 03-28-2011, 05:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Sgat8516 View Post
.. now the dryer runs fine, but takes 2x as long to dry a load...... vent's not blocked, dryer does warmup...
Most common cause of such problem is insufficient air flow. A restriction can be outside the dryer as well as inside. Make sure the blower wheel is properly attached to the motor shaft and all ducts are properly connected with no air leakage. Disconnect the vent hose on the back of the dryer and run a load to see if there is any difference in time.
If the problem still exist, you may want to replace the high limit thermostat (#48 on the diagram).
The thermal limiter (#50) you mentioned, is actually a thermal fuse. If it's open then the dryer would not work at all.
- The thermal cut-off kit Part number: AP2973862
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Washer and Dryer. Dryer model # 11060096991 fburr4054 Dryer Repair 1 11-21-2011 06:12 AM
kenmore dryer not working nfg kenmore Dryer Repair 1 12-10-2010 02:02 AM
kenmore dryer not working alfee Dryer Repair 2 02-09-2009 04:47 AM
Kenmore dryer stopped working dcn0021 Dryer Repair 0 01-25-2008 01:55 PM
Kenmore Dryer Stopped Working Rob Dryer Repair 4 09-19-2007 07:23 PM
