just took this drier apart and the the bearin AP4365923 is there any other partthat I should replace
Here are your parts Replacement parts for fex831csd models | AppliancePartsPros.comFor the difference in price ($3.00) I would order the kit and replace everything. Part number: AP2142648
Click on the picture for more info. Also check the idler wheel, the belt, the front drum support glides, drum seals and other seals in the air flow path. Give the interior including the blower wheel a good cleaning. You might as well check/clean your vent system while you are at it. |
THIS FORUM IS DEAD!!!!!!! |
