Replacement parts for AMANA LEA30AW DRYER- ELE | AppliancePartsPros.comCould be a number of things but I would start by checking the power.
The motor uses 120 volts while the heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
Then I would check the element and thermostats with a meter.
Heater first also checking that it is not grounded.
Then hi-limit and thermal fuses (Items 6 & 8 in Section 7)
Then the thermostat (Item 24 in Section 6)
