LG Dryer vibrates feels like drum is loose. Can move drum in and out about half inch
You need to check the rollers that the drum rides on. It has two rollers on the front and two rollers on the back. While your in there check and make sure the tub supports, front and rear, are tight. Be sure and check the blower wheel for lint build up as well. Here is a link to our parts diagram page, to help you with the tear down. Hope this helps. Section 3 replacement parts for LG DLG5988W Dryer | AppliancePartsPros.com
