Did not want to throw away another appliance if I can fix. Issue... Inconsistent Flame Gas Ignites and burns for a full cycle most of the time. Pulled off front pannel and observed that i would estimate 8 out of 10 times it is working properly. When it fails ignition element works fine but gas does not flow. Can someone provide on a priortiy basis which switch, on Igniter may be falling so i can run a meter on it for continity?
John
