lousy repairman
#1 Posted : Sunday, February 27, 2011 10:50:49 AM(UTC)
lousy repairman
My older Roper dryer wont heat after replacing thermostat, thermal fuse, and the heating element. Runs fine, cleaned lint areas, and will shut off when finished. Any suggestions what to do next?:confused:
#2 Posted : Wednesday, March 2, 2011 12:38:47 AM(UTC)
Replacement parts for EL5030VLO models | AppliancePartsPros.com
Does the timer advance and shut off in both timed dry and auto modes?
If it only advances in timed dry I would check the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Have you checked/replaced the hi-limit thermostat and the thermal cut-off (Items 15 and 6 in Section 4)?
Roper dryer wont heat after replacing parts (Dryer Repair)
by lousy repairman 3/6/2011 8:51:57 AM(UTC)
