Kenmore dryer has intermittent heat
Dryer Repair
Had some wet clothes today at the end of a drying cycle, so the dryer is not heating. Started the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer has intermittent heat
  #1 (permalink)
Old 12-21-2008, 07:49 PM
Junior Member
acillatem is on a distinguished road
Default Kenmore dryer has intermittent heat
Model Number: 110.76822693   Brand: Kenmore   Age: 5 - 10 years
Had some wet clothes today at the end of a drying cycle, so the dryer is not heating. Started the cycle over, just to be sure.......no heat. The last time this happened a few year ago, the local repair person was nice enough to tell me how check it was the thermal fuse.......by taking the 2 wires off the fuse and connecting them.......If the dryer starts heating up, then you need a thermal fuse. That is exactly what happened,and I replaced the fuse. I assumed that I was having the same problem today, so I did that little test again, but this time it didn't heat up. Hooked the wires back to the thermal fuse, tryed it again, and it started heating, so I let it go. Well, it was o.k. for maybe 10 minutes, then the heat was gone again. I'm just guessing here, and please correct me if I'm wrong, but isn't the only other thing it could be the thermostat?? Went and dried the clothes at the laundromat, came home and tried it again with the door open, holding the button down to simulate the door being closed, and tried it again.........it started heating up. I let go of the button, waited for it to completely stop, and tried it again......no heat. So it's an intermittent thing, but won't necessarily stay hot if it does start heating.One push of the button may get you heat, the next won't. I don't know if could be in the timer.....i.e. it "thinks" it's on the touchup cycle or??? Anyway, I hope it's a straightforward thing where if it's not the thermal fuse, then it has to be the thermostat, then I'd just probably order both and eliminate all doubt, but maybe there is something else that can cause this. Any hep greatly appreciated. Thanks in advance!
Related Models
Hoover 1100
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11012202100 WASHER
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 12-22-2008, 03:06 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
NEVER keep the door open while the heater is on, the thermal fuse will blow. The cycling thermostat will get room temperature and never turn off the flame till the fuse blows.
  #3 (permalink)
Old 12-22-2008, 07:16 AM
Junior Member
This was just to test to see if it was getting heat in the first place,while I was trying to troubleshoot it. Thanks for giving a reply that had nothing at all to do with my question.
  #4 (permalink)
Old 12-22-2008, 04:38 PM
Junior Member
What a useless forum this is.......not one bit of help all day except one person with a reply that had nothing to do with my question......thanks for nothing!
  #5 (permalink)
Old 12-22-2008, 04:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
The first failure suspect are the coils on the gas valve.
- The part number for the coil kit is AP3094251
P.S. If you do tests in a wrong way, it can create more problems and make a troubleshooting much more complicated.
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #6 (permalink)
Old 12-22-2008, 05:55 PM
Junior Member
Thanks for the reply! I wasn't trying to be a jerk regarding that other reply, and I understand what the person was saying, but I would have appreciated some help, such as you have given. The person at my local parts store thought it was most likely those solenoids, and I replaced them a little while ago, and it seems to be working fine now.Thanks!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer intermittent heat rpuglia Dryer Repair 3 09-30-2009 01:33 PM
Dryer intermittent to no heat edm812 Dryer Repair 6 07-30-2009 07:03 PM
2003 Kenmore Dryer : Intermittent Heat jeffsuwanee Dryer Repair 1 07-24-2009 07:22 AM
Intermittent dryer heat edm812 Dryer Repair 4 04-15-2009 06:08 AM
Kenmore Electric Dryer Intermittent Heat question bolingmike Dryer Repair 3 02-23-2009 06:28 PM
