Discuss
clanking noise
 in
Dryer Repair
dryer is making loud clanking noise.the drum roller appears to be the problem.I removed it and started dryer and the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » clanking noise
  #1 (permalink)
Old 02-26-2011, 01:46 PM
Junior Member
marknmelissa is on a distinguished road
Default clanking noise
Model Number: 11060722990   Brand: Kenmore   Age: More than 10 years
dryer is making loud clanking noise.the drum roller appears to be the problem.I removed it and started dryer and the noise was eliminated,but it didnt seem that anything was wrong with the roller wheel.Has anyone had the same problem?
Ads By Google
Related Models
Kenmore 11061062000 DRYER
Kenmore 11061064000 DRYER
Kenmore 11061066000 DRYER
Kenmore 1106107400 KENMORE GAS DRYER
Kenmore 1106107401 KENMORE GAS DRYER
Kenmore 1106107500 KENMORE GAS DRYER
Kenmore 1106107501 KENMORE GAS DRYER
Kenmore 1106107502 KENMORE GAS DRYER
Kenmore 1106107700 KENMORE GAS DRYER
Kenmore 1106107701 KENMORE GAS DRYER
Kenmore 1106107710 KENMORE GAS DRYER
Kenmore 1106107800 KENMORE GAS DRYER
Kenmore 1106107801 KENMORE GAS DRYER
Kenmore 1106107803 KENMORE GAS DRYER
Kenmore 11061082000 DRYER
Kenmore 1106108400 KENMORE ELECTRIC DRYER
Kenmore 11061084000 DRYER
Kenmore 1106108401 KENMORE ELECTRIC DRYER
Kenmore 1106108500 KENMORE ELECTRIC DRYER
Kenmore 1106108501 KENMORE ELECTRIC DRYER
Kenmore 11061086000 DRYER
Kenmore 1106108700 KENMORE ELECTRIC DRYER
Kenmore 1106108701 KENMORE ELECTRIC DRYER
Kenmore 1106108710 KENMORE ELECTRIC DRYER
Kenmore 1106108800 KENMORE ELECTRIC DRYER
Kenmore 1106108801 KENMORE ELECTRIC DRYER
Kenmore 1106108802 KENMORE ELECTRIC DRYER
Kenmore 11061092000 DRYER
Kenmore 11062032100 ELECTRIC DRYER
Kenmore 11062036100 ELECTRIC DRYER
Kenmore 11062042100 DRYER
Kenmore 11062052100 DRYER
Kenmore 11062054100 DRYER
Kenmore 11062056100 DRYER
Kenmore 11062062100 DRYER
Kenmore 11062062101 ELECTRIC DRYER
Kenmore 11062062102 ELECTRIC DRYER
Kenmore 11062064100 DRYER
Kenmore 11062064101 ELECTRIC DRYER
Kenmore 11062064102 ELECTRIC DRYER
Kenmore 11062066100 DRYER
Kenmore 11062066101 ELECTRIC DRYER
Kenmore 11062066102 ELECTRIC DRYER
Kenmore 1106207400 KENMORE GAS DRYER
Kenmore 1106207401 KENMORE GAS DRYER
Kenmore 1106207420 KENMORE GAS DRYER
Kenmore 1106207421 KENMORE GAS DRYER
Kenmore 1106207430 KENMORE GAS DRYER
Kenmore 1106207431 KENMORE GAS DRYER
Kenmore 1106207432 KENMORE GAS DRYER
Kenmore 1106207433 KENMORE GAS DRYER
Kenmore 1106207500 KENMORE GAS DRYER
Kenmore 1106207501 KENMORE GAS DRYER
Kenmore 1106207502 KENMORE GAS DRYER
Kenmore 1106207511 KENMORE GAS DRYER
Kenmore 1106207600 KENMORE GAS DRYER
Kenmore 1106207601 KENMORE GAS DRYER
Kenmore 1106207700 KENMORE GAS DRYER
Kenmore 1106207701 KENMORE GAS DRYER
Kenmore 1106207702 KENMORE GAS DRYER
Kenmore 11063012100 ELECTRIC DRYER
Kenmore 11063012101 DRYER
Kenmore 11063012102 ELECTRIC DRYER
Kenmore 11063014100 ELECTRIC DRYER
Kenmore 11063014101 DRYER
Kenmore 11063014102 ELECTRIC DRYER
Kenmore 11063022100 DRYER
Kenmore 11063022101 ELECTRIC DRYER
Kenmore 11063022102 ELECTRIC DRYER
Kenmore 11063024100 DRYER
Kenmore 11063024101 ELECTRIC DRYER
Kenmore 11063024102 ELECTRIC DRYER
Kenmore 11063032100 ELECTRIC DRYER
Kenmore 11063032101 ELECTRIC DRYER
Kenmore 11063032102 ELECTRIC DRYER
Kenmore 11063034100 ELECTRIC DRYER
Kenmore 11063034101 ELECTRIC DRYER
Kenmore 11063034102 ELECTRIC DRYER
Kenmore 11063036100 ELECTRIC DRYER
Kenmore 11063036101 ELECTRIC DRYER
Kenmore 11063036102 ELECTRIC DRYER
Kenmore 11063042100 ELECTRIC DRYER
Kenmore 11063042101 DRYER
Kenmore 11063042102 ELECTRIC DRYER
Kenmore 11063046100 ELECTRIC DRYER
Kenmore 11063046101 DRYER
Kenmore 11063046102 ELECTRIC DRYER
Kenmore 11063052100 DRYER
Kenmore 11063052101 DRYER
Kenmore 11063052102 ELECTRIC DRYER
Kenmore 11063062100 DRYER
Kenmore 11063062101 ELECTRIC DRYER
Kenmore 11063062102 ELECTRIC DRYER
Kenmore 11063064100 DRYER
Kenmore 11063064101 ELECTRIC DRYER
Kenmore 11063064102 ELECTRIC DRYER
Kenmore 11063066100 DRYER
Kenmore 11063066101 ELECTRIC DRYER
Kenmore 11063066102 ELECTRIC DRYER
Kenmore 1106307400 KENMORE GAS DRYER
Kenmore 1106307401 KENMORE GAS DRYER
Kenmore 1106307402 KENMORE GAS DRYER
Kenmore 1106307500 KENMORE GAS DRYER
Kenmore 1106307501 KENMORE GAS DRYER
Kenmore 1106307502 KENMORE GAS DRYER
Kenmore 1106307504 KENMORE GAS DRYER
Kenmore 1106307600 KENMORE GAS DRYER
Kenmore 1106307601 KENMORE GAS DRYER
Kenmore 1106307602 KENMORE GAS DRYER
Kenmore 1106307603 KENMORE GAS DRYER
Kenmore 1106407400 KENMORE GAS DRYER
Kenmore 1106407401 GAS DRYER
Kenmore 1106407500 KENMORE GAS DRYER
Kenmore 1106407501 KENMORE GAS DRYER
Kenmore 1106407502 KENMORE GAS DRYER
Kenmore 1106407540 KENMORE GAS DRYER
Kenmore 1106407700 KENMORE GAS DRYER
Kenmore 1106407701 KENMORE GAS DRYER
Kenmore 1106407702 KENMORE GAS DRYER
Kenmore 1106407740 KENMORE GAS DRYER
  #2 (permalink)
Old 03-02-2011, 01:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for KENMORE 11060722990 | AppliancePartsPros.com
Clanking/thumping is usually one of the rear support rollers.
Often it is a flat spot on the roller that is not very obvious.
Also check the support shafts.
Not a bad idea to also look at where the rollers run on the drum, sometimes crud, lint etc. can stick there and cause a thumping.
Check that the seam on the drum is OK.
Another area that can cause thumping are the front and rear drum seals.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
clanking noise with gas dryer tjason13 Dryer Repair 0 06-28-2009 08:13 PM
Dryer clanking noise when running Dude Dryer Repair 4 06-09-2009 05:01 AM
Slipping/clanking GE Washer GEAngel Washer Repair 4 02-10-2008 10:36 AM
Frigidaire front load - clanking noise champ649 Washer Repair 4 01-12-2008 02:08 AM
Dryer makes clanking noise Leonard07 Dryer Repair 2 12-05-2007 02:45 PM
