my dryer drys fine but does not turn off
Here are your parts Replacement parts for fde700fhso models | AppliancePartsPros.comHere is the wiring diagram http://manuals.frigidaire.com/prodinfo_pdf/Webster/131826200.pdfHave you checked/cleaned your moisture sensor (Item 8 in Section 2). The below is if the timer is not advancing in auto modes. This is two metal strips with a space between them. When clothes are wet there is moisture between the strips and this passes a small electrical current. The board monitors this and holds the timer off. When the clothes are dry there is no moisture so the current stops flowing and the board then advances the timer. Any dirt etc. between the strips will make the unit think the clothes are still wet and not advance the timer. Clean between the strips with a damp cloth, drying thoroughly . If this does nothing try cleaning with isopropyl alcohol or electronics cleaner, just make sure that all the vapors have dissipated before trying it. |
THIS FORUM IS DEAD!!!!!!! |
