Discuss
Dryer Motor Not Working
 in
Dryer Repair
I Test For Voltage At The Motor. I Have Voltage There.could There Be Anything Else Beside The Motor. The
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Motor Not Working
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-19-2007, 05:31 AM
starr starr is offline
Junior Member
starr is on a distinguished road
Default Dryer Motor Not Working
Model Number: 11070952990   Brand: Kenmore   Age: 5 - 10 years
I Test For Voltage At The Motor. I Have Voltage There.could There Be Anything Else Beside The Motor. The Belt Was Broken When Itookthe Dryer Part.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-19-2007, 01:44 PM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Default
Whirlpool DOTT dryer, you have 120 volts at the motor??? and it is dead? if this is so, about the only thing could be a bad motor if voltage at the motor itself , altho I have never seen one go bad like this, they usually hum or something....check that broken belt switch, kills power to the motor when the belt breaks, door switch, check it too....
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #3 (permalink)
Old 10-20-2007, 02:44 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pins 4& 5 should have 115 volts there and motor should run. If so, you have an open motor, sort of rare.
__________________
  #4 (permalink)
Old 10-20-2007, 04:52 PM
Junior Member
Default
there was 120 v at the blue @white wires . tell me more about the broken belt switch where is it located? must the belt be on to work?can i by pass the switch to see if the motor turn on? starr thank for help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer motor wire diagram loweluckie Dryer Repair 8 02-10-2008 10:43 PM
Motor not working properly W. Henderson Washer Repair 0 08-14-2007 06:06 PM
Dryer motor R&R Pete Dryer Repair 0 08-14-2007 12:38 PM
Roper dryer - 95 volts on timer motor jazbird1 Dryer Repair 1 08-10-2007 08:49 PM
Dryer motor is noisey and sometimes humms and doesn't start Tudeman Dryer Repair 2 07-20-2007 03:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
