Discuss
No heat in Maytag Electric dryer
 in
Dryer Repair
My dryer won't heat up. I have replaced several parts already, heater element, high temp thermostat located on the heater
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat in Maytag Electric dryer
  #1 (permalink)
Old 02-24-2011, 08:46 PM
Junior Member
mikecohrs is on a distinguished road
Default No heat in Maytag Electric dryer
Model Number: mde8600ayq   Brand: Maytag   Age: 5 - 10 years
My dryer won't heat up. I have replaced several parts already, heater element, high temp thermostat located on the heater element, moisture sensor, and have checked the thermal fuse also located on the heater element for continuity and it was fine. Also did check the circuit breaker in case it was 2 breakers and one was tripped, but it was fine. What else could cause this, another fuse, timer, switch? and is there a way to verify the part is defective before i throw away another $100.
Related Models
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
Maytag MDE9706AZW DRYER- ELE
Maytag MDE9766AYW DRYER- ELE
Maytag MDE9766AZW DRYER- ELE
Maytag MDE9800AYQ DRYER- ELE
Maytag MDE9800AYW DRYER- ELE
Maytag MDE9800AZQ DRYER- ELE
Maytag MDE9800AZW DRYER- ELE
Maytag MDE9806AYA DRYER- ELE
Maytag MDE9806AYW DRYER- ELE
Maytag MDE9806AZW DRYER- ELE
Maytag MDE9876AYW DRYER- ELE
Maytag MDET236AYW DRYER- ELE
Maytag MDET236AZW DRYER- ELE
Maytag MDET336AYW DRYER- ELE
Maytag MDET336AZW DRYER- ELE
Maytag MDET446AYW DRYER- ELE
Maytag MDET446AZW DRYER- ELE
Maytag MDG100PN1 MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1L MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1W MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAGL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAKL MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDG10CSEGL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10MNAAW MANUAL, PARTS (DRYER GAS)
Admiral MDG10MNAGW DRYER- GAS
Maytag MDG10MNEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDEGL MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG10PDEGW MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG10PSABW MANUAL, PARTS (DRYER ELE)
Maytag MDG10PSAGL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDG10PSAGW MAYTAG LAUNDRY (DRYER ELE)
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSABW MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSAGL MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSAGW MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSEGL MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG11MNAAW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG11MNAGW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG11MNEGW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG11PDAAL MAYTAG LAUNDRY (DRYER GAS)
Maytag MDG11PDAAW MAYTAG LAUNDRY (DRYER GAS)
Maytag MDG11PDABL MAYTAG LAUNDRY (DRYER GAS)
Maytag MDG11PDABW MAYTAG LAUNDRY (DRYER GAS)
Maytag MDG11PDAGL MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG11PDAGW MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG11PDEGL MANUAL, PARTS (DRYER GAS)
Maytag MDG11PDEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG120P1HW MANUAL, PARTS (DRYER GAS)
Maytag MDG120PHVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG12CSAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG12CSAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG12CSABW MANUAL, PARTS (DRYER GAS)
Maytag MDG12CSAGW MANUAL, PARTS (DRYER GAS)
Maytag MDG12CSEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG12MNAAW MANUAL, PARTS (DRYER GAS)
  #2 (permalink)
Old 02-25-2011, 02:53 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for MAYTAG MDE8600AYQ DRYER- ELE | AppliancePartsPros.com
I would check the power first, it is not unheard of for a breaker to go bad, just looking at the breaker is not good enough.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 02-25-2011, 05:31 AM
Junior Member
Default
Power checks out both at the plug and in the control panel. My next guess may be the timer. Is there a way to test this with a voltmeter to know if it is bad?
  #4 (permalink)
Old 02-25-2011, 07:23 AM
Senior Expert
APP Volunteer
Default
Here is a service manual
16023110 Maytag Sloped Front Dryer Repair Service Manual - ApplianceDigest.com
You will have to join the site to download the manual but it is well worth it.
This is a great site for the appliance DIYer.
See Page 10-22
The following only applies if the unit will not turn on.
You only mentioned checking one thermal fuse, you have to check both.
The second one is on the blower (Item 10 in Section 7 of the parts)
The most common cause for this one blowing is a malfunctioning or plugged vent system.
The hi-limit is in the heater circuit so I would check that.
Also the cycling thermostat contacts.
Then the temperature switch.
You could unplug the unit and set it to mid scale on a timed dry cycle.
By the look of it timer contacts 3 should be closed.
Note: Be sure to disconnect at least one side of any part you are measuring for resistance. This ensures you do not read an alternate/parallel circuit path.
__________________
  #5 (permalink)
Old 02-25-2011, 01:44 PM
Junior Member
Default
Ok, so i set the timer switch in the middle of a timed cycle, unplugged circuit 3, which is the black and red wires on the top of the switch, and checked for continuity. The circuit did not show continuity. I then rotated the switch all the way around and never was able to get continuity. Does this indicate the timer is defective?
  #6 (permalink)
Old 02-25-2011, 03:43 PM
Senior Expert
APP Volunteer
Default
Yes I would say that the timer is toast.
__________________
  #7 (permalink)
Old 02-26-2011, 05:51 AM
Junior Member
Default
Thank You very much.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag electric dryer heat stays on SusanMKoehler@comcast.net Dryer Repair 3 06-28-2016 07:09 AM
Maytag Electric Dryer Won't Heat ayersl Dryer Repair 7 02-26-2010 03:09 PM
Maytag Performa Electric Dryer No Heat linktlife Dryer Repair 7 11-03-2009 04:07 PM
Maytag Electric Range - Lights on but no heat bunangst Oven Repair (including Ranges and Cooktops) 5 10-05-2009 06:49 AM
Amana/Maytag Electric oven won't heat above 250 quickmom Oven Repair (including Ranges and Cooktops) 1 06-11-2009 02:53 PM
