jon75127
#1 Posted : Saturday, December 20, 2008 1:02:43 PM(UTC)
jon75127
We have a GE electric dryer with no heat. We relaced the heat element and the thermal limiter switch. We have tested all the components, thermostats, switches, motors, etc. for the proper voltage/continuity, and everything checks out o.k. We can run the dryer, but we still have no heat. We read 120 volts at the heating element conections and at any point around the element, while running.
Any ideas??...our local appliance repairman is stumped on this one too.
Drags1998
#2 Posted : Saturday, December 20, 2008 3:56:55 PM(UTC)
Drags1998
RE-SET the circut breaker in the HOUSE!!!!! :eek:
#3 Posted : Sunday, December 21, 2008 2:48:12 AM(UTC)
Read the voltage across the heater (not to Neutral), should be 240 volts.
Also when you took your resistance readings did you disconnect at least one side of any device you were reading, this prevents reading an alternate/parallel circuit path.
Did you check the heating element to frame (Ground) for resistance. Should be an open. Also what was the heating element's resistance, should be approximately 10 ohms.
If all thermal fuses, timer contacts and thermostats in the heater's circuit path are good then all that is left is the centrifugal switch on the motor.
jon75127
#4 Posted : Sunday, December 21, 2008 4:41:18 AM(UTC)
jon75127
Denman-
All of our resistance readings were done with the device disconnected. We did check the element to ground...it was open. The element was new, I did check the resistance but can't remember the reading. Also tested the centrifugal switch on the motor. It checked o.k.
Trying to get ahold of my buddy to have him reset his breaker as Drags1998 has suggested. Will keep you all informed.
Thanks for all your help!
Jon75127
jon75127
#5 Posted : Monday, December 22, 2008 4:16:22 PM(UTC)
jon75127
Drags1998-
You are correct. The breaker would not reset. We replaced it today and now we are up and running.
Thank you so much,
jon75127
Drags1998
#6 Posted : Monday, December 22, 2008 4:47:52 PM(UTC)
Drags1998
COOL!!!!!!!! Glad to help!!!!!!!!!:D
