| » Testing a whirlpool 3398095 start switch. |
Model Number: LEC7848DQ0 Brand: Whirlpool Age: 5 - 10 years
How do I test the start switch on my whirlpool dryer, part number 3398095.
Replacement parts for WHIRLPOOL LEC7848DQ0 | AppliancePartsPros.com See the attachment for the wiring diagram As you can see from the wiring diagram it is a relay and not a switch, So contacts R1 to R2 should be 0 ohms when it is pushed in. If it is OK the next thing to check would be the thermal fuse (Item 7 in Section 3) Should also be 0 ohms. If blown (infinite ohms) be sure to check/clean your vent system before replacing as this is the most common cause of it blowing.
__________________
Which terminals are R1 and R2? Is that the Blue to Blue in the schematic, or Blue to Pink/Black? Blue to Blue I have continuity, but any blue wire to pink does not have continuity. Thanks for your help.
I am not 100% sure but I believe Blue to Blue is R1 and R2, so you should have 0 ohms when the button is pressed. Infinite ohms when not presses.
A Blue to Pink/Black will then be the coil. Use a higher meter scale to check this (200 Kohms).
__________________
| Display Modes | |
| Whirlpool Estate, Checking 3 wire Start Switch | rankins66 | Dryer Repair | 6 | 11-13-2010 05:06 AM |
| testing the on/off switch | CAJ1976 | Dishwasher Repair | 0 | 11-04-2010 07:16 PM |
| Testing Lid Switch | Laynemcn | Washer Repair | 0 | 05-23-2010 07:23 AM |
| Testing rotary start switch | bdrg | Dryer Repair | 1 | 01-15-2009 05:31 PM |
| How do I replace my Whirlpool Washer Start Switch? | Tammie Henderson | Washer Repair | 2 | 09-05-2008 09:46 AM |
