terryleeharvey
#1 Posted : Wednesday, February 23, 2011 6:23:13 AM(UTC)
terryleeharvey
I have replaced 3 thermostats and 1 fuse, cleaned the entire vent system and now instead of intermittent heat I have none. I wonder if all along it was the heating element, which was replaced a few years ago, going bad? How and where would I test it. Terry
sidfink43
#2 Posted : Thursday, February 24, 2011 4:50:41 PM(UTC)
sidfink43
You can test it with a multi-meter set on Ohms. Disconnect one of the two connections and set your meter to Ohms. You should get 10 to 15 Ohms if the element is intact.
Maytag Dryer No Heat - Burnt Wire - Causes? (Dryer Repair)
by RobH7 11/11/2012 6:56:49 PM(UTC)
Maytag Dryer No Heat (Dryer Repair)
by bros250 7/1/2012 3:16:45 AM(UTC)
Maytag dryer NO HEAT (Dryer Repair)
by vettyfunny 1/24/2010 3:59:26 PM(UTC)
Maytag dryer no heat (Dryer Repair)
by fireeatr 7/20/2009 6:59:33 PM(UTC)
maytag dryer no heat (Dryer Repair)
by rdnyjoh 3/24/2008 6:12:38 PM(UTC)
by rdnyjoh 3/24/2008 5:56:51 PM(UTC)
