Discuss
whirlpool electric dryer shuts off during cycle
 in
Dryer Repair
My dryer turns on and heats up but shuts off after just a few min. What would cause this? Please
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool electric dryer shuts off during cycle
  #1 (permalink)
Old 02-23-2011, 04:57 AM
Junior Member
rusty rice is on a distinguished road
Default whirlpool electric dryer shuts off during cycle
Model Number: LER3624EQ1   Brand: Whirlpool   Age: 5 - 10 years
My dryer turns on and heats up but shuts off after just a few min. What would cause this? Please help
Related Models
Whirlpool LER3624EQ1 ELECTRIC DRYER
Whirlpool LER3624JQ0 DRYER
Whirlpool LER3624JQ1 RESIDENTIAL DRYER
Whirlpool LER3624JQ2 29" ELECTRIC DRYER
Whirlpool LER3624PQ0 29" ELECTRIC DRYER
Whirlpool LER3624PQ1 29" ELECTRIC DRYER
Whirlpool LER3634EW0 ELECTRIC DRYER
Whirlpool LER3634EW1 DRYERS
Whirlpool LER3634EW2 ELECTRIC DRYER
Whirlpool LER3634JW0 ELECTRIC DRYER
Whirlpool LER3634JW1 RESIDENTIAL DRYER
Admiral LER3725AAC RANGE- S/C F/S ELE
Whirlpool LER4434AN0 ELECTRIC DRYER
Whirlpool LER4434AN1 ELECTRIC DRYER
Whirlpool LER4434AQ0 Residential Dryer
Whirlpool LER4434AQ1 ELECTRIC DRYER
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
  #2 (permalink)
Old 02-23-2011, 07:00 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LER3624EQ1 | AppliancePartsPros.com
If you have to wait several minutes before you can restart it then it is probably the motor overheating. It then trips it's internal thermal protect.
You have to wait till the motor cools down and the thermal protect resets before you can restart.
Try manually turning the drum in the correct direction. It should turn fairly easily.
If not it may be overloading the motor.
You may want to try this on a couple other dryers to get a feel for it.
If it is hard to turn run your fingers along the back and front edges of the drum just to ensure something has no gotten jammed in there. Be careful in case it is a sharp object. If nothing is there you will have to open it up and find out what is causing excessive drag on the drum.
Check/clean your vent system. Could be a partial clog is forcing hot air back onto the motor. May be the blower seal (Item 16 in Section 3) is shot.
Could just be that the interior of the machine is clogged with lint.
If all OK then odds are that your motor is on it's last legs.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Electric Dryer Shuts Down walkthesky Dryer Repair 18 10-13-2010 09:45 AM
electric dryer heat shuts off after a minute ddaigle Dryer Repair 0 07-25-2010 10:34 AM
Whirlpool Electric Dryer doesn't start until timer reaches cool down cycle noclaf1 Dryer Repair 6 09-03-2009 08:28 AM
kenmore electric dryer shuts off indycamaro79z28 Dryer Repair 1 02-11-2008 03:09 PM
Electric Dryer Shuts Off tspeedy Dryer Repair 1 10-01-2007 02:54 AM
