Originally Posted by: ford855006 my whirlpool dryer has no heat Ford, First, check and reset both breakers for the dryer at the breaker box(several times) ,then check for the heat and operation. With the dryer power off, slide the dryer out, and remove the back panel. In the right lower area of the cabinet, you'll see the heat inlet flue/pipe, on the lower area you should see 2 thermostats and wires, make sure the wires and thermostats are not damaged, broken, burnt. Also, in the same area, you'll see the removable panel, that the heater assembly is mounted to, you can remove the panel and visually inspect the heater coil for damage or breakage. If all checks, or appears OK, we'll need to get a multi meter, so we can do resistance and voltage checks on the complete heater circuit. :) :) :)
