Discuss
Gas dryer heat to 100 degrees
 in
Dryer Repair
The dryer seems to work fine but does not get up to high temperature which I think should be around
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer heat to 100 degrees
  #1 (permalink)
Old 02-22-2011, 08:15 AM
Junior Member
trouts2 is on a distinguished road
Default Gas dryer heat to 100 degrees
Model Number: FDG336LBS0   Brand: Frigidaire   Age: More than 10 years
The dryer seems to work fine but does not get up to high temperature which I think should be around 160. It only goes to 100.
The coils were replaced last year. A new belt was installed two weeks ago and that's when the temp was found to be low but the belt may not be related.
The vent is clear, good flow out which is think is what it always is. There is no or very little dust inside the machine mostly on the bottom plate but the ducts, front area and blower all clean.
I dryer has two thermostats. One I think is for a high limit and the other by the blower for regular temp regulation. I think the one by the blower is partly working. That's a guess from reading past posts.
The parts breakdown I have only gives a figure number for the thermostat.
In a prior post Gene posted the following:
Frigidaire Gas Dryer works but No Heat, Why??
The parts are:
1. The igniter (#74 on the burner break down diagram)
2. The flame sensor (#79 on the burner break down diagram)
3. The safety thermostat (#33 on the cabinet break down diagram)
4. The heat control thermostat (#15 on the motor break down diagram)
The above was for a FDG336NBS1. I think mine is the same and the heat control in #4 is the same as mine.
The unit starts with a big orange glow which then goes to a flame. I can't see well through the vent. The flame does not go out i.e. it is not starting and stopping but seems to be on all the time. This is a little puzzling as I would think it ran full blast for a while then shut off and keep doing that to regulate the temperature. Instead of going on/off it's going all the time but not up to high temp. That would seem like the the gas flow is restricted so can only make a small flame to only get the temp to 100. So I'm not sure if it's the thermostat or restricted flame. ??
I'm looking for a head check on the problem and if correct is the part above the one for my dryer?
Ads By Google
Related Models
Frigidaire FDG336LBS0 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG336LBS1 Frg(v1) / Gas Dryer
Frigidaire FDG336LBS2 Frg(v0) / Gas Dryer
Frigidaire FDG336LES0 Frg(v1) / Gas Dryer
Frigidaire FDG336MRES0 Frg(v0) / Dryer
Frigidaire FDG336NBS0 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG336NBS1 Frg(v2) / Gas Dryer
Frigidaire FDG336NBS2 Frg(v0) / Gas Dryer
Frigidaire FDG336NES0 Frg(v2) / Gas Dryer
Frigidaire FDG336RBS0 Frg(v3) / 27 " Gas Dryer
Frigidaire FDG336RBS1 Frg(v1) / Gas Dryer
Frigidaire FDG336RBS2 Frg(v1) / Gas Dryer
Frigidaire FDG336RBT0 Frg(v4) / 27 " Gas Dryer
Frigidaire FDG336RBT1 Frg(v2) / Gas Dryer
Frigidaire FDG336RBT2 Frg(v2) / Gas Dryer
Frigidaire FDG336RES0 Frg(v1) / Gas Dryer
Frigidaire FDG336RES1 Frg(v1) / Gas Dryer
Frigidaire FDG336RES2 Frg(v0) / Free Standing Dryer
Frigidaire FDG336RET0 Frg(v2) / Gas Dryer
Frigidaire FDG336RET1 Frg(v2) / Gas Dryer
Frigidaire FDG336RET2 Frg(v0) / Dryer
Frigidaire FDG436RBS1 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG436RBS2 Frg(v1) / Gas Dryer
Frigidaire FDG436RBT1 Frg(v2) / 27 " Gas Dryer
Frigidaire FDG436RBT2 Frg(v2) / Gas Dryer
Frigidaire FDG436RES0 Frg(v3) / Gas Dryer
Frigidaire FDG436RES1 Frg(v1) / Gas Dryer
Frigidaire FDG436RES2 Frg(v0) / Dryer
Frigidaire FDG436RET0 Frg(v4) / Gas Dryer
Frigidaire FDG436RET1 Frg(v2) / Gas Dryer
Frigidaire FDG437GHS0 Frg(v0) / Dryer
Frigidaire FDG546DBD0 Frg(v2) / 27 " Gas Dryer
Frigidaire FDG546DBD1 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG546DBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG546DBW1 Frg(v2) / 27 " Gas Dryer
Frigidaire FDG546LBS0 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG546LBS1 Frg(v1) / Gas Dryer
Frigidaire FDG546LBS2 Frg(v3) / Gas Dryer
Frigidaire FDG546LBT0 Frg(v2) / 27 " Gas Dryer
Frigidaire FDG546LBT1 Frg(v2) / Gas Dryer
Frigidaire FDG546LES0 Frg(v3) / Gas Dryer
Frigidaire FDG546NBS0 Frg(v3) / 27 " Gas Dryer
Frigidaire FDG546NBS1 Frg(v3) / Gas Dryer
Frigidaire FDG546NBS2 Frg(v1) / Gas Dryer
Frigidaire FDG546NBT0 Frg(v4) / 27 " Gas Dryer
Frigidaire FDG546NBT1 Frg(v4) / Gas Dryer
Frigidaire FDG546NBT2 Frg(v2) / Gas Dryer
Frigidaire FDG546NES0 Frg(v4) / Gas Dryer
Frigidaire FDG546RBS0 Frg(v5) / 27 " Gas Dryer
Frigidaire FDG546RBS1 Frg(v5) / Gas Dryer
Frigidaire FDG546RBS2 Frg(v4) / Gas Dryer
Frigidaire FDG546RBT0 Frg(v6) / 27 " Gas Dryer
Frigidaire FDG546RBT1 Frg(v6) / Gas Dryer
Frigidaire FDG546RBT2 Frg(v5) / Gas Dryer
Frigidaire FDG546RES0 Frg(v1) / Gas Dryer
Frigidaire FDG546RES1 Frg(v1) / Gas Dryer
Frigidaire FDG546RES2 Frg(v1) / Dryer
Frigidaire FDG546RES3 Frg(v1) / Dryer
Frigidaire FDG546RET0 Frg(v2) / Gas Dryer
Frigidaire FDG546RET1 Frg(v2) / Gas Dryer
Frigidaire FDG546RET2 Frg(v2) / Dryer
Frigidaire FDG546RET3 Frg(v2) / Dryer
Frigidaire FDG558GGS0 Frg(v0) / Dryer
Frigidaire FDG558GHS0 Frg(v0) / Dryer
Frigidaire FDG646GES0 Frg(v0) / Gas Dryer
Frigidaire FDG646RHS0 Frg(v0) / Dryer
Frigidaire FDG647RFS0 Frg(v0) / Dryer
Frigidaire FDG647RFS1 Frg(v0) / Free Standing Dryer
Frigidaire FDG648GFS0 Frg(v1) / Gas Dryer
Frigidaire FDG648GFS1 Frg(v1) / Free Standing Dryer
Frigidaire FDG648GFT0 Frg(v2) / Gas Dryer
Frigidaire FDG648GFT1 Frg(v2) / Free Standing Dryer
Frigidaire FDG648GHS0 Frg(v1) / Dryer
Frigidaire FDG648GHT0 Frg(v2) / Dryer
Frigidaire FDG700FHS0 Frg(v0) / Dryer
Frigidaire FDG747GES0 Frg(v0) / Gas Dryer
Frigidaire FDG747RBS0 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG747RBS1 Frg(v1) / Gas Dryer
Frigidaire FDG747RBT0 Frg(v0) / Gas Dryer
Frigidaire FDG747RBT1 Frg(v2) / Gas Dryer
Frigidaire FDG747RES0 Frg(v1) / Gas Dryer
Frigidaire FDG747RET0 Frg(v2) / Gas Dryer
Frigidaire FDG847GCS0 Frg(v1) / 27 " Gas Dryer
Frigidaire FDG847GCT0 Frg(v2) / 27 " Gas Dryer
Frigidaire FDG847RBS0 Frg(v3) / 27 " Gas Dryer
Frigidaire FDG847RBT0 Frg(v2) / 27 " Gas Dryer
Frigidaire FDG848GFS0 Frg(v1) / Gas Dryer
Frigidaire FDG848GFT0 Frg(v2) / Gas Dryer
Frigidaire FDG855RHS0 Frg(v0) / Dryer
Frigidaire FDG875GHS0 Frg(v1) / Dryer
Frigidaire FDG875GHT0 Frg(v2) / Dryer
Frigidaire FDG8970EW0 Frg(v0) / Gas Dryer
Frigidaire FDG8970EW1 Frg(v0) / Gas Dryer
Frigidaire FDG8970EW2 Frg(v0) / Free Standing Dryer
Frigidaire FDG8971EW0 Frg(v0) / Gas Dryer
Frigidaire FDG8971EW1 Frg(v0) / Dryer
Frigidaire FDG8971EW2 Frg(v0) / Dryer
Frigidaire FDG8971EW3 Frg(v0) / Gas Dryer
Frigidaire FDG8974HW0 Dryer - Frigidaire / Dryer
Frigidaire FDG8976FS0 Frg(v1) / Dryer
Frigidaire FDG8976FS1 Frg(v0) / Dryer
Frigidaire FDG8976FW0 Frg(v2) / Dryer
Frigidaire FDG8977ES0 Frg(v0) / Gas Dryer
Frigidaire FDG8977EW0 Frg(v0) / Gas Dryer
Frigidaire FDGB23RGS0 Frg(v0) / Dryer
Frigidaire FDGB23RGS1 Frg(v0) / Free Standing Dryer
Frigidaire FDGB23RGS2 Dryer - Frig/best Buy
Frigidaire FDGB34RGS0 Frg(v0) / Dryer
Frigidaire FDGB34RGS1 Frg(v0) / Free Standing Dryer
Frigidaire FDGB34RGS2 Dryer - Frig/best Buy
Frigidaire FDGB55RGS0 Frg(v0) / Dryer
Frigidaire FDGB55RGS1 Frg(v0) / Free Standing Dryer
Frigidaire FDGC847GFS1 Frg(v0) / Dryer
Frigidaire FDGR436RHS0 Frg(v0) / Dryer
Frigidaire FDGS69RHW0 Dryer - Frig/wards
Frigidaire FDGS69RHW1 Dryer - Frigidaire
Frigidaire FDH25J1 Dehumidifier
Frigidaire FDH25J2 DEHUMIDIFIER
Frigidaire FDH25J4 Frigidaire/dehumidifier
Frigidaire FDH25J5 Frigidaire/dehumidifier
  #2 (permalink)
Old 02-24-2011, 05:45 AM
Junior Member
Default
Ran the dryer again.
On starting the glow gets large in about 15-20 seconds and it lights something. The glow stops and I can see a flame flickering in the front (I'm looking through the back vent).
The flickering flame is always there and the dryer temp at the back vent goes to 120 degrees. I think it should be going to 160. If anyone knows the temp I should be measuring please let me know.
I'm not sure how dryers operate. I would think that they should cycle the heat. That is, the dryer flame would always be on high and when it got to temp it would shutoff. Then go on again and so on cycling until the clothes were done. What I see is the flame in the front is always going and no cycling. The temp gets to 120 and stays there until the timer gets to cool down. The flame in the front goes off and eventually the dryer stops.
The drying times have increased so I think 120 is too low. I don't think it's the thermostat but not sure. Again, what I think I should see is cycling. Instead I see a flame all the time but the temp does not get to 160 which I think is what it should get to. ??
  #3 (permalink)
Old 03-05-2011, 04:48 AM
Junior Member
Default
Took the front panel off and got a look at the flame which was low. I tried to clean around the gas valve outlet with a wire brush but could not get access to the tip. I would just get my little finger in there and wiped and scrapped around the outlet with my fingernail. I did not feel any obstructions in there either hard or soft like cobwebs or built up lint, nothing. Everything was clear and clean in there.
I rapped the gas valve several times with the screwdriver handle and buttoned up the machine. It then ran with much higher temp. I put in a load of washed clothes and it dried them in the usual time so I think at least for now it will run properly.
Just for reference if someone is reading this for info the thermostat is 140-145 and not a problem.
The heat selection comes from resistors in the heat selection knob which adds a bias to the voltage on the thermostat making it cut out early for low temps. It was thought that possibly the selection switch was broken or stuck causing the thermostat to cut out low but it never cycled anyway so not the problem. The problem was low flame and I think cured by rapping the gas valve.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat above 425 degrees eurohopper Oven Repair (including Ranges and Cooktops) 0 01-09-2010 11:11 AM
Oven won't heat beyound 285 degrees Jim Wells Oven Repair (including Ranges and Cooktops) 0 11-16-2009 07:11 AM
oven doesn't heat higher than 375 degrees aml14103 Oven Repair (including Ranges and Cooktops) 5 10-17-2009 05:28 PM
Oven will not heat over 220 degrees sandymb58 Oven Repair (including Ranges and Cooktops) 0 01-12-2009 05:57 AM
oven won't heat above 135 degrees John T. Oven Repair (including Ranges and Cooktops) 1 06-30-2008 09:10 AM
