Discuss
gas dryer with heat issue
 in
Dryer Repair
So here is the problem... When I turn the dryer on the igniter glows and the gas fires up as
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer with heat issue
  #1 (permalink)
Old 02-19-2011, 03:51 PM
Junior Member
ahjort is on a distinguished road
Default gas dryer with heat issue
Model Number: glgq332as0   Brand: Frigidaire   Age: 5 - 10 years
When I turn the dryer on the igniter glows and the gas fires up as it should, after a couple of minutes of normal operation, the gas cuts off (maybe this is a normal cycling thing). After it cools down for a couple minutes the igniter glows again but the gas will not fire. After a few seconds, the igniter shuts down. Then after a minute or so the cycle starts all over again...igniter glows but no gas fire then the igniter shuts down. This cycle keeps repeating with no gas fire! I replaced the flame sensor (AP2142636), but this made no difference! By the way... the vent is clear, and i tried running it with the vent hose disconnected just to be sure (it made no difference)!
Also, when I opened the dryer up to replace the flame sensor, I noticed on the control panel that the moisture sensor (small Integrated Circuit Board) (AP3220652) was fried. I considered this completely unrelated because the preset controls on the dial have not been working for a long time. We have been using the timer setting instead. I figured I would replace this sensor while I had it apart. I did. After replacing both the flame sensor and the burned out moisture sensor. I put it back together figuring I had it licked. As mentioned above the problem has not been resolved. I opened it back up only to find that the brand new moisture sensor was fried just like the original!!! Are these problems related and how do I fix them?
Any advice would be greatly appreciated!
Ads By Google
Related Models
Frigidaire GLGQ332AS0 Dryer - Frig Gallery
Frigidaire GLGQ332AS1 Dryer - Frig Gallery
Frigidaire GLGQ332AS2 Frigidaire/gas Dryer
Frigidaire GLGQ332AS3 Frigidaire/gas Dryer
Frigidaire GLGQ332AS4 Frigidaire/dryer
Frigidaire GLGQ332MAS0 Frigidaire/dryer
Frigidaire GLGQ442CES0 Frigidaire Canada/gas Dryer
Frigidaire GLGQ642AS0 Dryer - Frig Gallery
Frigidaire GLGQ642AS1 Dryer - Frig Gallery
Frigidaire GLGQ642AS2 Frigidaire/gas Dryer
Frigidaire GLGQ642AS3 Frigidaire/gas Dryer
Frigidaire GLGQ642AS4 Frigidaire/dryer
Frigidaire GLGQ942CS0 Frigidaire/dryer
Frigidaire GLGR1042FC0 DRYER
Frigidaire GLGR1042FC1 DRYER
Frigidaire GLGR1042FS0 Frigidaire/dryer
Frigidaire GLGR1042FS1 DRYER
Frigidaire GLGR1042FS2 DRYER
Frigidaire GLGR104FSS0 Frigidaire/dryer
Frigidaire GLGR104FSS1 DRYER
Frigidaire GLGR104FSS2 DRYER
Frigidaire GLGR331AS0 Dryer - Frig Gal
Frigidaire GLGR331AS1 Dryer - Frigidaire Gallery
Frigidaire GLGR331AS2 Frigidaire/gas Dryer
Frigidaire GLGR331AS3 Frigidaire/gas Range
Frigidaire GLGR331AS4 Frigidaire/dryer
Frigidaire GLGR331DQ0 Frigidaire/dryer
Frigidaire GLGR331MAS0 Frigidaire/dryer
Frigidaire GLGR341AS0 Dryer - Frigidaire Gallery
Frigidaire GLGR341AS1 Dryer - Frigidaire Gallery
Frigidaire GLGR341AS2 Frigidaire/gas Dryer
Frigidaire GLGR341AS3 Frigidaire/gas Dryer
Frigidaire GLGR341AS4 Frigidaire/gas Dryer
Frigidaire GLGR341CC0 Frigidaire/dryer
Frigidaire GLGR642AS0 Dryer - Frigidaire Gallery
Frigidaire GLGR642AS1 Dryer - Frigidaire Gallery
Frigidaire GLGR642AS2 Dryer - Frig Gallery
Frigidaire GLGR642AS3 Frigidaire/gas Dryer
Frigidaire GLGR642AS4 Frigidaire/gas Dryer
Frigidaire GLGR642AS5 Frigidaire/gas Dryer
Frigidaire GLGS389EBA Frigidaire/gas Range
Frigidaire GLGS389EBB Frigidaire/gas Range
Frigidaire GLGS389EBC Frigidaire/range
Frigidaire GLGS389EQA Frigidaire/gas Range
Frigidaire GLGS389EQB Frigidaire/gas Range
Frigidaire GLGS389EQC Frigidaire/range
Frigidaire GLGS389ESA Frigidaire/gas Range
Frigidaire GLGS389ESB Frigidaire/gas Range
Frigidaire GLGS389ESC Frigidaire/range
Frigidaire GLGS389FBA Frigidaire/gas Range
Frigidaire GLGS389FBB GAS RANGE
Frigidaire GLGS389FBC GAS RANGE
Frigidaire GLGS389FBD GAS RANGE
Frigidaire GLGS389FBE GAS RANGE
Frigidaire GLGS389FBF GAS RANGE
Frigidaire GLGS389FBG GAS RANGE
Frigidaire GLGS389FQA Frigidaire/gas Range
Frigidaire GLGS389FQB GAS RANGE
Frigidaire GLGS389FQE GAS RANGE
Frigidaire GLGS389FSA Frigidaire/gas Range
Frigidaire GLGS389FSB GAS RANGE
Frigidaire GLGS389FSC GAS RANGE
Frigidaire GLGS389FSD GAS RANGE
Frigidaire GLGS389FSE GAS RANGE
Frigidaire GLGS389FSF GAS RANGE
Frigidaire GLGS389FSG GAS RANGE
Frigidaire GLGT1031CS0 Frigidaire/laundry Center
Frigidaire GLGT1031CS1 Frigidaire/laundry Center
Frigidaire GLGT1031FS0 Frigidaire/laundry Center
Frigidaire GLGT1031FS1 LAUNDRY CENTER
Frigidaire GLGT1031FS2 LAUNDRY CENTER
Frigidaire GLGT1031FS3 LAUNDRY CENTER
Frigidaire GLGT1031FS5 LAUNDRY CENTER
Frigidaire GLGT1041AS0 Lc - Frig Gallery
Frigidaire GLGT1041AS1 Lc - Frig Gallery
Frigidaire GLGT1041AS2 Frigidaire/laundry Center
Frigidaire GLGT1142CS0 Frigidaire/laundry Center
Frigidaire GLGT1142CS1 Frigidaire/laundry Center
Frigidaire GLGT1142FS0 Frigidaire/laundry Center
Frigidaire GLGT1142FS1 LAUNDRY CENTER
Frigidaire GLGT1142FS2 LAUNDRY CENTER
Frigidaire GLGT1142FS3 LAUNDRY CENTER
Whirlpool GLHA7900W0
Whirlpool GLHA7900W1
Whirlpool GLHA7900W2
Whirlpool GLHE7900W0 Residential Dryer
Frigidaire GLHS234ZAB1 Frigidaire/refrigerator
Frigidaire GLHS234ZAQ1 Frigidaire/refrigerator
Frigidaire GLHS234ZAW1 Frigidaire/refrigerator
Frigidaire GLHS237ZAB1 Frigidaire/refrigerator
Frigidaire GLHS237ZAB5 Frigidaire/refrigerator
Frigidaire GLHS237ZAB6 Frigidaire/refrigerator
Frigidaire GLHS237ZAQ1 Frigidaire/refrigerator
Frigidaire GLHS237ZAQ5 Frigidaire/refrigerator
Frigidaire GLHS237ZAQ6 Frigidaire/refrigerator
Frigidaire GLHS237ZAW1 Frigidaire/refrigerator
Frigidaire GLHS237ZAW5 Frigidaire/refrigerator
Frigidaire GLHS237ZAW6 Frigidaire/refrigerator
Frigidaire GLHS237ZCB0 Frigidaire/refrigerator
Frigidaire GLHS237ZCB1 Frigidaire/refrigerator
Frigidaire GLHS237ZCB2 Frigidaire/refrigerator
Frigidaire GLHS237ZCQ0 Frigidaire/refrigerator
Frigidaire GLHS237ZCQ1 Frigidaire/refrigerator
Frigidaire GLHS237ZCQ2 Frigidaire/refrigerator
Frigidaire GLHS237ZCW0 Frigidaire/refrigerator
Frigidaire GLHS237ZCW1 Frigidaire/refrigerator
Frigidaire GLHS237ZCW2 Frigidaire/refrigerator
Frigidaire GLHS238ZDB0 Frigidaire/refrigerator
Frigidaire GLHS238ZDB1 Frigidaire/refrigerator
Frigidaire GLHS238ZDB2 Frigidaire/refrigerator
Frigidaire GLHS238ZDB3 Frigidaire/refrigerator
Frigidaire GLHS238ZDB4 Frigidaire/refrigerator
Frigidaire GLHS238ZDB5 Frigidaire/refrigerator
Frigidaire GLHS238ZDB6 Frigidaire/refrigerator
Frigidaire GLHS238ZDB7 Frigidaire/refrigerator
Frigidaire GLHS238ZDB8 Frigidaire/refrigerator
Frigidaire GLHS238ZDQ0 Frigidaire/refrigerator
Frigidaire GLHS238ZDQ1 Frigidaire/refrigerator
Frigidaire GLHS238ZDQ2 Frigidaire/refrigerator
Frigidaire GLHS238ZDQ5 Frigidaire/refrigerator
  #2 (permalink)
Old 02-21-2011, 04:23 PM
Junior Member
Default
So...I deduced by reading multiple posts on this forum that the root of my problem was probably the gas valve coils! After replacing them the issue with the lack of heat IS cured!! Thanks to all the previous posters' help in showing me the way to resolve this!
BUT...I will start a new thread to bring to the forefront my issue with the burned out moisture sensor....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer doesn't heat up - but that isn't my issue mitch8 Dryer Repair 3 10-07-2010 06:48 PM
Roper Dryer Heat issue LouVillian Dryer Repair 2 08-31-2010 02:40 AM
Maytag Gas Dryer - No heat Issue... dsmstorm Dryer Repair 4 12-02-2009 03:38 AM
dryer heat issue rvw67 Dryer Repair 0 05-06-2009 05:27 PM
GE Dryer-Heat issue iceman5cc5 Dryer Repair 1 03-25-2008 03:40 PM
