| » Dryer |
Model Number: LGQ8000JQ4 Brand: Whirlpool Age: 1 - 5 years
Dryer Runs Fine But Has No Heat Gas Is On
Perform the troubleshooting as described in one of our previous posts: No Heat on Gas Dryer
Here are the break down diagrams for the Whirlpool dryer Model LGQ8000JQ4 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The thermal fuse is shown as #7 on the diagram while the cycling thermostat is #9 and the flame sensor is #49.
The igniter and the coils are shown as #4, #13 & #14 on the diagram. You have to click on the link posted in the previous reply and read it through for more information. - The thermal fuse Part number: AP3132867 - The cycling thermostat Part number: AP3045874 - The igniter Part number: AP3094138 - The flame sensor Part number: AP2910747 - The coil kit Part number: AP3094251 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGQ8000JQ4 29"GAS DRYER | AppliancePartsPros.com Gene.
__________________
You can not perform any reliable diagnostic by guessing. You can buy a simple ohmmeter for about $10 and save much more.
__________________
__________________
Okay, so I feel like I don't really know what I'm doing with the multimeter, but here is what I find. The fuse has continuity (my meter beeps when I touch the leads to where the plugs go). The thermostat has 4 wires, two on the long sides and two on the back (the two on the back are closest to the red thing). The long sides have continuity, but the back does not. Does this indicate that the thermostat is bad? Are those two supposed to have continuity?
Did you disconnect the wires from the thermal fuse before you test it?
The cycling thermostat should have continuity between the large terminals and you should not test the small terminals. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter Gene.
__________________
| Display Modes | |
