Discuss
Neptune dryer displays 8.8.
 in
Dryer Repair
This morning try to dry same clothes and when I push the start bottom 8.8. show at screen and did
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Neptune dryer displays 8.8.
  #1 (permalink)
Old 12-16-2008, 11:22 AM
Junior Member
salas65 is on a distinguished road
Default Neptune dryer displays 8.8.
Model Number: MDG5500AWW   Brand: Maytag   Age: 1 - 5 years
8.8. show at screen and did no run anymore unplug for about 20 minutes
did not work...help please
Related Models
Maytag MDG5500AWW DRYER- GAS
Maytag MDG5806AWK DRYER- GAS
Maytag MDG5806AWW DRYER- GAS
Maytag MDG5960BWW DRYER- GAS
Maytag MDG6000AWQ DRYER- GAS
Maytag MDG6000AWW DRYER- GAS
Maytag MDG6000AXW DRYER- GAS
Maytag MDG6000BWQ DRYER- GAS
Maytag MDG6000BWW DRYER- GAS
Maytag MDG6200AWQ DRYER- GAS
Maytag MDG6200AWW DRYER- GAS
Maytag MDG6400AWQ DRYER- GAS
Maytag MDG6400AWW DRYER- GAS
Maytag MDG6460AWW DRYER- GAS
Maytag MDG6657BWQ DRYER- GAS
Maytag MDG6657BWW DRYER- GAS
Maytag MDG6700AWM DRYER- GAS
Maytag MDG6700AWW DRYER- GAS
Maytag MDG6800AWQ DRYER- GAS
Maytag MDG6800AWW DRYER- GAS
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
  #2 (permalink)
Old 12-17-2008, 03:34 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is your parts breakdown
Model MDG5500AWW
Here is the tech sheet, service manual and troubleshooting chart
http://www.servicematters.com/maytag...s/16026750.pdf
http://www.servicematters.com/maytag...s/16023110.pdf
http://www.servicematters.com/maytag...s/63902110.pdf
Could not find a 8.8 error but 8 looks like it is a keyboard error.
Try to run the diagnostics, you may be able to narrow it down a little
Unplug the unit and open up the control console
Remove the ribbon cable from the control board
Looks like the ribbon cable has a connector on the end so clean the edge connector on the cable and the board with a tooth brush and some electronics cleaner (available at electronics supply stores) or isopropyl alcohol (available at drug stores).
Also check the ribbon cable for hairline cracks running across the tracks. A magnifying glass is useful here.
Be gentle and do not reinstall the cable till all the solvent has evaporated.
Give it a try, You may get lucky.
If no good, use a meter to check the keyboard switches.
You are trying to confirm that the keyboard is the problem since the most likely culprit is the keyboard but the control board could also do this.
You want to take the guessing out of ordering a part since most places will not allow the return of electronic components.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
neptune dryer captain1 Dryer Repair 2 01-04-2011 11:46 AM
Dryer Displays "PF" juliocvs Dryer Repair 3 11-04-2009 11:53 AM
dryer will not start displays bfranklin Dryer Repair 0 03-19-2009 04:22 PM
Neptune Dryer red574 Dryer Repair 3 01-12-2009 05:16 AM
Sensor on Neptune gas dryer charliew Dryer Repair 1 09-30-2007 10:59 PM
