Discuss
Dryer Thermal Fuse
 in
Dryer Repair
The thermal fuse on my amana dryer is blown. I have tested it with a multimeter and I am certain
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Thermal Fuse
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-18-2011, 08:10 AM
Junior Member
jrl10_5 is on a distinguished road
Default Dryer Thermal Fuse
Model Number: ALE643RAW   Brand: Amana   Age: 5 - 10 years
The thermal fuse on my amana dryer is blown. I have tested it with a multimeter and I am certain it is the issue. The heating element and high limit thermostat are showing resistance and continuity respectively. My question is . . .what do I need to do to make sure this does not happen again? There is a reason the fuse blew, right? I know I need to clean out the vent, but I am nervous that this will keep happening because our dryer vents to the roof and everything I have read states that those get clogged easily. Do you have any suggestions or tips before I replace the fuse and hope this does not keep happening. Thank you.
Related Models
Amana ALE643RAW DRYER- ELE
Amana ALE643RBC DRYER- ELE
Amana ALE643RBW DRYER- ELE
Amana ALE643RCW DRYER- ELE
Amana ALE665SAC DRYER- ELE
Amana ALE665SAW DRYER- ELE
Amana ALE866SAC DRYER- ELE
Amana ALE866SAW DRYER- ELE
Amana ALE866SBC DRYER- ELE
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
  #2 (permalink)
Old 02-18-2011, 06:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by jrl10_5 View Post
...what do I need to do to make sure this does not happen again?...
...I am nervous that this will keep happening because our dryer vents to the roof and everything I have read states that those get clogged easily...
The dryer vent, especially if it goes on top of the roof, must be cleaned professionally all the way though the outlet at least once in five years. So you have to hire a pro to do it for you.
The dryer itself has to be cleaned inside once a year. It is very important for safety and its good performance.
Would not hurt if you will replace the cycling thermostat together with the thermal fuse. It is located on the blower housing cover.
Keep the dryer vent and the dryer itself clean and everything should be fine.
- The cycling thermostat Part number: AP4053749
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas dryer - no thermal fuse ?? Chris830 Dryer Repair 1 10-29-2010 01:02 PM
thermal fuse on kenmore dryer bigmatt Dryer Repair 11 08-08-2010 08:42 AM
Thermal Fuse for Gas Dryer bobby h Dryer Repair 5 08-29-2009 05:02 AM
whirlpool gas dryer thermal fuse ipaontap Dryer Repair 5 08-18-2009 07:14 AM
thermal fuse blown, gas dryer crazyman Dryer Repair 1 09-07-2008 02:28 PM
